Motor oil - Ford Powerstroke Diesel Forum
post #1 of 25 Old 12-16-2012, 07:02 AM Thread Starter
z250kid's Avatar
Motor oil
i was wondering where i can get 5w-40 non synthetic for winter. I have 164000 miles so its to late to switch. I use 15-40 shell but there 5-40 is synthetic. Is it okay to switch or no. Does anyone know where to get non synthetic 5w-40
1996 F350 4x4 Powerstroke Diesel
Afe Stage 2
3 Inch Downpipe,Cat-Delete,90 degree elbow(ss)
Diy Exhust Brake
Hpx Crossover
z250kid is offline
post #2 of 25 Old 12-16-2012, 07:20 AM
tpndrcn's Avatar
Quoted: 2 Post(s)
Don't know what area you live in but Farm and Fleet, Oreillys, Walmart all carry Rotella 5-40w sythentic. Its ok to switch ,go ahead and look foward to easier starts. However, be prepared if you have oil leaks to see a little more!
tpndrcn is offline
post #3 of 25 Old 12-16-2012, 08:51 AM
backwoodsboy's Avatar
No issues switching at 164,000, unless you are burning/leaking a considerable amount of oil already.
Stay away from Rotella T-6. There have been multiple independent studies showing it holds up poorly to viscosity breakdown and oil shear tests.
Go with something like Valvoline Premium Blue Extreme, or better yet Schaeffer's 7000 or 9000 series oils. Both are offered in 5w40.
Napa carries the Valvoline, and offer's 10% off when you order online and pick up in store. Doesn't make it all that much more expensive that T-6.
Chrome don't get ya home
backwoodsboy is offline
post #4 of 25 Old 12-16-2012, 09:07 AM Thread Starter
z250kid's Avatar
i have small oil leak but ill adress that in the spring. I got amsoil for now
Afe Stage 2
Diy Exhust Brake
Hpx Crossover
z250kid is offline
post #5 of 25 Old 12-16-2012, 11:46 AM
I run valvoline premium blue 5-40 synthetic, switched at 150k when I bought the truck and now have 161k and no issues
2000 F350 Lariat dually 6 speed 4" mbrp, 6637, Banks brake. Just rolled over 60k miles
2016 keystone cougar 333mkswe
2016 Ford Escape Titanium 2.0 ecoboost
2014 vw Jetta sportwagen tdi. sold
1995 dodge 2500 drag truck. 6.82@104 in the 1/8th. Sold
1996 dodge 2500 auto. sold
1997 F250 auto. sold
1997 F250 5 speed. sold
1998 dodge auto 2500. sold
2001 dodge 5sped 2500. sold
2003 F250 6.0 auto. sold
2004 F350 6.0 6 speed. sold
ctd12valve95 is offline
post #6 of 25 Old 12-16-2012, 04:01 PM
bha4424's Avatar
amsoil has a 5w30 diesel oil that you can run. I would stay with synthetic though; it's a much better oil and Amsoil is one of the best oils out there. I ran the lighter weight oil for a while but the truck did not run as well. I would stick to 15w40.
bha4424 is offline
post #7 of 25 Old 12-17-2012, 12:50 PM Thread Starter
z250kid's Avatar
Im running the amsoil 15-40 it starts so much eaiser! My friend sells it at his shop told me synthetic 15-40 flows better than non and it cranks over quicker. It idles so smoothly now motor sounds quiter also. Truck sounds happy now to replace these injectors. Im glad i switched.
Afe Stage 2
Diy Exhust Brake
Hpx Crossover
z250kid is offline
post #8 of 25 Old 12-17-2012, 08:15 PM
Actually, this article Turbo Diesel Register Tech: Lube Oil, Religion, Specifications and the TDR says that the Rotella T6 5W-40 is a good oil.
97 F250 PSD...6637 Filter upgrade...3" Diamond Eye DP...DFuser EBPV eliminator...Improved "Blue" CPS...
Qwazert is offline
post #9 of 25 Old 12-17-2012, 09:22 PM
T-6 used to be a quality out. Rotella changed the sheer characteristic of the oil 10 years ago, making it incapable of handing the high-sheer environment of a HEUI system.
Here's a chart of oil breakdown vs hours.
There is also an entire thread on the subject over on PSA
Oil Oil Oil - PowerStrokeArmy
post #10 of 25 Old 12-18-2012, 11:43 AM
Wow...I guess it just depends who's report you read, and WHAT they are testing!
I've read good things about the Valvoline Premium Blue, so each time we go to Bellingham, I pick up a gallon...will try that at the next change.
Qwazert is offline
