front drive shaft u joints which one?
Im hoping i just ordered the correct front drive shaft ujoints for my 97 f250 with the 7.3, went to advance and they showed nothing for front u joints for a hd f250 everything was except hd so i looked on rockauto at the 96 f250 and found that moog part # 265 said it was for the front driveshaft and is greaseable so i went ahead and ordered a pair as one in the shaft has about 3/8" play in it, im hoping the 96 and 97 have the same setup can somebody verify for me that i ordered the right ujoint?
Anytime I need to order anything for my 97 I go with 96. The only part so far that I've found was different was the brake master cylinder has to be ordered for 97.
outstanding good to hear that, hopefully the u joints take care of the howling i get when i put it in 4x4, found the front ujoint by the diff had a decent amount of play in it(3/8") in one direction, gonna flush the front and rear diffs as well, then i have a slight clunking and vibration coming from the front end, thinking tires are to blame for the vibration not sure if its gonna be ball joints or wheel bearings for the clunking........
