dana 50 to dana 60
what all parts will swap between a dana 50 and dana 60?
Search feature is a wonderful thing. There are a ton of writeups on the subject with complete parts lists.
How-To: Dana 60 Swap - Diesel Forum - TheDieselStop.com
How-To: Dana 60 Swap Since there is no "official" how-to on the Dana 60 swap in the F-250's, I thought I would put one together and distribute it to the PSD community. A little history on the Dana 60: The Dana/Spicer 60 is manufactured by Dana Corp. There are rear & front axle versions. The Dana 60 can be identified by the 10 bold asymmetrical cover, along with the "60" cast into the housing. Ford was the first company to use the Dana 60 in the 1950's. During the mid 1970's, Ford, Chevrolet, and Dodge all were using the axle in the front and rear of vehicles. GM began phasing out the Dana 60 in '88 in favor of the independent front suspension. Dodge used the Dana 60 in a passenger side drop till '94 when they redesigned the Ram pickup. Dodge stopped using the Dana 60 in their 3rd generation Ram's. Ford still today uses the Dana 60 in the front of their F-250, F-350, F-450, and F-550 trucks. The axle was manufactured in 2 different versions, a king pin and a ball joint version. All 3 manufactures have used both the king pin and the ball joint axle. Dana 60 Specs: Ring Gear Diameter: 9-3/4" Pinion Shaft Diameter: 1-5/8" Axle Tube Diameter: 3-1/8" Gear Ratios: 3.31:1 to 7.17:1 Carrier break: 3.31:1 - 4.10:1 and 4.56:1 - 7.17:1 Weight: 500# roughly Parts Needed from F-350 for Swap: - '86-'97 Dana 60 ('86-'93 are King Pin versions) - F-350 Front Leaf Springs - Track Bar - Track Bar Bracket - Driver Side U-Bolt Plate New Parts Needed: - Tie Rod End (Moog ES3009R) x 2 - Tie Rod Crossover (Moog DS1071) - Tie Rod to Pitman Arm (Moog DS1068) - Tie Rod Adjustment Sleeve (Moog ES2012S) x 2 - U-bolts (new) x 4 - Gear Oil (Preferred Weight and Brand) x 3 - Diff Cover Gasket or Form-a-Gasket - 24" of Vent Hose Use '95-'97 Dana 60- ( '94 or older Dana 60 means brake mods - different caliper and caliper mount). 1. Replace all the seals and u-joints in the axle while it is out. 2. Turn rotors & replace hub bearings. It’s easier to do w/ axle out than it is with it in the truck 3. Get the front of the truck onto jack stands and the tires off. 4. Remove brake calipers. If you are using a '95-'97 axle, tie the caliper up out of the way 5. Next remove the shocks. 6. Remove the steering linkage from the axle itself. If you have a tie rod separator, you can use it. If you don't, take a 2-5# sledge hammer and smack the stud on the tie rod end; it might take a couple of good hits to get it out depending on how long, if ever, the end has been out. Don't worry about screwing up the end as you will not use it again. 7. Cut off axle U-bolts 8. Remove the pivot point bolts (use good impact gun). With the impact on one side and a wrench on the other, the nut should come right off. Once the nut is off both pivot point bolts, use your 2# sledge to drive the bolts out. Make sure you are not directly under the axle when you drive the bolts out so the axle does not fall on you. If the axle does not fall, grab one of the outer ends of the axle and wiggle it until one side falls. Once one side falls, the other side will go with it because of the axle shafts. You can now drag the axle out from under the truck. More than likely, the axle will come out in 2 pieces once you start dragging. To get to hear should take you about 1:15 hours 9. If you are swapping in the front F-350 leaf springs, now is the time to remove the old F-250 springs. The best way to do this is to remove the rear bolt first to take the tension off the shackle. Once the rear bolt is out, remove the front bolt. You may have to do a little prying to get the springs to come out of the mounts. 10. Install the F-350 springs in the opposite as you remove the F-250 springs. 11. Now is the hardest part of the swap. You need to remove the F-250 pivot brackets. The bolts that go through the vertical portions o the cross member are straight forward in their removal since they are all connected on one side. The bolts on the top of the cross member are a pain. They are true bolts and you will have to fish a wrench between the cross member and oil pan to get them lose. Once they are lose, you will more than likely have to grind the majority of the bolt off so it will fit up between the cross member and oil pan to come out. 12. The track bar bracket should now be ready to go in. The bracket utilizes the factory holes on the rear vertical portion of the engine cross member. There is only 1 possible way for the holes to line up. When you hold it up there you will see which holes are the ones you need to use. Get the bracket installed and you will be ready to slide the axle under the truck. 13. Once you have done what you are going to do with the springs (or didn't do), have the old pivot brackets out, and have the track bar bracket installed, now is the time to slide the new axle into place. With the axle slid into place, it is best to take a jack and raise 1 side at a time starting with the driver side to align the leaf springs with the spring perch on the axle. Once you have a side lined up on the springs, go ahead and install the U-bolts for that side; don't tighten them, just snug them. Now go do the same for the passenger side. Once you have both sides lined up, tighten the U-bolts down. 14. Move an extra set of jack stands under the axle so you can put the weight of the truck on the axle. 15. Install the track bar. 16. Now we are ready to install the steering linkage. When you put your steering linkage together, do so on a work bench. You will want to run your tie rod ends and tie rods 1/2 way through your adjuster sleeve. This will make sure that the sleeves, ends, and rods all have clean threads on them and make the self-alignment much easier. Once you have them put together, go ahead and install them on the truck. Remember, the long rod goes between the steering knuckles and the short rod comes from the pitman arm down to the cross over rod. The adjustment on the short rod goes into the pitman arm. 17. Install your shocks and brakes. 18. Now you are ready to install the tires & go back through and double check all the bolts for tightness. 19. You will now need to check your drive shaft for proper length. There are a couple options you can take here. With the truck on its own weight, measure from transfer case yoke to axle yoke. This is the measurement your drive shaft will need to be with the drive shaft in the neutral position. Depending on the length of your stock drive shaft, you may be able to leave it as it is (mine was fine like it was according to the drive line shop I use). If it isn't the proper length, you can have a machine shop cut and rebalance your old shaft. If you are lucky enough to have the whole F-350 you got the axle from, you can use the double cardon drive shaft from the F-350. If you do, you will need to change the front yoke on the transfer case to accept the double cardon portion of the drive shaft. The easiest part of the swap is doing a quick self-alignment so you can drive it to get your official alignment done at a shop. I set my steering wheel straight and adjusted the cross bar to what eye ball looked to be straight tires. I then took a tape measure, and a helper, and measured from outside of tread to outside of tread on the front of the tires. I repeated the measurement on the rear of the tires. I made changes until the measurements were within a 1/16" difference. When the alignment shop did my alignment, they said I was 8* off total toe and 20* off steer straight. Not too bad if you ask me. Just make sure to double check all the bolts after a couple hundred miles. |
Take it from me. You will be FAR ahead by buying a D60 than you will be to rebuild your D50. I didn't install ball joints, but I replaced everything else, including brakes. I have about $900 in the front end of my truck. Labor alone was a nightmare, and I can think of better ways to spend 2 weekends than by fighting rusty bolts in my dirveeway, driving to the shop to rent goofy sockets, or getting the wrong parts and having to go back and wait for the new stuff to arrive. Totally not worth the effort.
Enough of my whining. There are a few companies out the who sell BRAND NEW Dana 60s. I'm going that route soon. I do not agree with how the market is selling used junk for over $1000 (in my area only???). To me, used Dana 60s for that price is not worth the investment, especially when you can buy a BRAND NEW unit for $1500 (shipping not included). Examples below: 06 F250 axles, Dana 60, Sterling $1200.00 OBO (Seneca, SC) 06 F250 axles, Dana 60, Sterling $1200.00 OBO Parting out 1997 F-350 4x4 - $1500 (Loganville) Parting out 1997 F-350 4x4 Ford Dana 60 Front Axle - $1000 (Marietta) Ford Dana 60 Front Axle 1 ton Ford Axles (Dana 60 & 10.25) - $1300 (Baton Rouge) http://batonrouge.craigslist.org/pts/3374643975.html Kingpin Ford Dana 60 and matching 10.25 rear axle. Matching set. Unbolted them from a Ford single wheel, got the springs and swaybars still attached. Bolt right up to a TTB truck. 93 Ford Dana 60 front axle - $850 (Albany,GA) 93 Ford Dana 60 front axle Dana 60's 14 bolts (Inverness) Dana 60's 14 bolts New Inventory! Chevy kingpins, Ford kingpins and ball joints, SRW, DRW...3.54, 4.10's 4.56's Stock to custom built. Gear sets, chrome moly axles... E-mail with what you need. I also have a coulpe Ford divorced np205's 03 F250 4wd Axles Front and Rear - $1200 (Orlando) 03 F250 4wd Axles Front and Rear 03 F250 4wd Front and rear axles. Excellent Condition, Complete with front springs. (WOW!) Ford 1 ton 4x4 axles (Muscle Shoals) Ford 1 ton 4x4 axles 94 model Dana 60 front, ball joint type, with matching 10 |
I grabbed mine up for 600. A deal can be had, you just gotta wait for it.
Yeah, that's what I was forced to do. Rebuild the 50 & keep an eye out for a decently price D60.
hell i bought a whole truck with a d60 in it lol, just cant bare to part it out, but i traded my old winch for the d60 off a 95, if you pull the springs and track bar mount and everything attached down it will all bolt in exactly how it came out, older models like 93 and down will require you to grind off the tab on the brake line and it will go rite back on too, easily, make sure you get lots of brake fluid kause it will be everywhere when your done, good luck
![]() Just curious is all. Do we add all this "stuff" because somebody else did; or is it actually REQUIRED? |
trac bar keeps axle from sliding one way or another, springs more so for front to rear, the 350 springs are not needed but they are a bit softer on the spine imho, i have turbo idi springs under mine, and well the u bolt plates will not work from the d50, it is a flat square tube around what could be easily called a CV axle, looks acts and works the exact same in this case, but is in the end exposed, the whole system wears out quickly, as opposed to the d60 which is a solid monobeam axle completely contained and in a sealed system, does not wear out near as bad and doesnt need to keep the center section dropped too, just the trac bar dropped or extended, i have one laying in my driveway i can take piks of the different parts if you would like, just let me know
ive already rebuilt my d50 a couple years ago. well everything but brakes and diff. cost was under $500. took about 18 hours. i was just curious as to what parts that are on a d50 will work on a d60.
