High pressure oil pump? - Ford Powerstroke Diesel Forum
post #1 of 23 Old 12-14-2012, 04:44 PM Thread Starter
Red '97's Avatar
So after numerous jumping through hoops, the shop my trucks at has finally figured out that the high pressure oil pump is bad. anyone know of where i can get a good new one, high quality preferably but also stock, for a good price?
-Conner
1997 F-250 Long Bed Extended Cab
--7.3 Powerstroke E40D Auto
--4.10 Rear End
--280,000 Miles
-Napa 6637 DIY CAI
-3 inch DP, 5 inch under truck, 6 inch Mitre!!
-2nd gen Wicked Wheel from Dieselsite
-Tony Wildman 6 Position Chip
Broke College Kid Mod
Now residing in LARAMIE, WY for school at the University of Wyoming! Hit me up if youre around, I'm always down for a hot rodding adventure
"Never cut what you can untie"
--Buckaroo Proverb
Red '97 is offline
post #2 of 23 Old 12-14-2012, 04:49 PM
Diesel_brad's Avatar
Quoted: 4 Post(s)
Terminator Engineering sells the T-500 for $450 with a core
Last I heard a "stock" 17* was 400 and it is almost a crapshoot on the rebuild
Looking for Blue 40-20-40 seats. PM me !!!!!!!
Diesel_brad is offline
post #3 of 23 Old 12-15-2012, 12:33 PM Thread Starter
Red '97's Avatar
is that the cost brand new?
-Conner
--4.10 Rear End
--280,000 Miles
-Napa 6637 DIY CAI
--Buckaroo Proverb
Red '97 is offline
post #4 of 23 Old 12-16-2012, 11:35 PM Thread Starter
Red '97's Avatar
bump
10 characters
-Conner
--4.10 Rear End
--280,000 Miles
-Napa 6637 DIY CAI
--Buckaroo Proverb
Red '97 is offline
post #5 of 23 Old 12-17-2012, 12:17 AM
Did they try changing the ipr? Lots of times they will diagnose it as a bad hpop and in reality all it is is just the ipr. They're not cheap per say, but cheaper than a new hpop.
Sent from my iPhone using AutoGuide.com App
2001 F350 SRW CC 4WD LB
ZF6 w/ Southbend, 220k, DIY Intake, WW,NonEBPV Pedestal, CCV Mod, Gauges (Boost, Pyro), 2in Leveling Kit, 4" Straight MBRP, AIH Delete, 2-12" Kicker Comp's, Pioneer Amps
2001 F350 DRW EC 2WD (Rolled Over)
2000 F550 CC 2WD
Automatic, Jasper 4R100 w/Derale Pan & 6.0 Cooler, DIY Intake, AIH Delete, 4" MBRP,
Schnot is offline
post #6 of 23 Old 12-17-2012, 06:46 AM
Full A-Team Member
Fordman247365's Avatar
x2, check IPR first, ICP also since it controls pressure. and if you can swing it while in there upgrade the HPOP to the one of choice, T500, SRP1.4.6.7, etc
Elmo/Shane
96 F350 4x4
Everything.
And its expensive.
476,000 Miles
"100% worked for, 100% paid for"
Fordman247365 is offline
post #7 of 23 Old 12-17-2012, 09:56 PM Thread Starter
Red '97's Avatar
the IPR was replaced just before they diagnosed the bad hpop, and i believe the checked the icp but ill have to double check. the truck is stock and probably will be till who knows when, i mean no tuning either. i was planning on putting a regular stock hpop in it, is there any reason to upgrade to an aftermarket hpop even on a stock truck?
-Conner
--4.10 Rear End
--280,000 Miles
-Napa 6637 DIY CAI
--Buckaroo Proverb
Red '97 is offline
post #8 of 23 Old 12-17-2012, 10:01 PM
Full A-Team Member
I would at least put a 17* SD pump in it, there is one on Ebay for $150 right now
Elmo/Shane
96 F350 4x4
Everything.
And its expensive.
476,000 Miles
post #9 of 23 Old 12-17-2012, 10:28 PM
Delivers Pizzas For Fun!
ol_Blue97's Avatar
If u want to get a new pump u can get a stock bosch 17*... but may be the same price as a t500
FRANK THE TANK
DIY INTAKE - HYDRA CHIP - MARTY'S E-FUEL - 250/200s
05 AXLE SWAP 3.73 - 2.5" PURE PERF. LIFT COILS - FOX SHOCKS
BTS TRANS - TYMAR DOWN PIPE - 4" EXHAUST
Waiting To Be Installed... gtx4294r, studs, springs, HPOP?
Originally Posted by STROKED_NY_023 View Post
You are so smart Frank, I dont care what Terry says.
ol_Blue97 is offline
post #10 of 23 Old 12-18-2012, 07:42 AM Thread Starter
Red '97's Avatar
what would be the benefit of doing it on a stock truck? and will a 17* from a superduty go on the same way as a stock obs pump?
-Conner
--4.10 Rear End
--280,000 Miles
-Napa 6637 DIY CAI
--Buckaroo Proverb
Red '97 is offline
