Dual Mass Flywheel - Ford Powerstroke Diesel Forum
post #1 of 6 Old 10-29-2007, 03:20 PM Thread Starter
Dual Mass Flywheel
Hey Guys,
I have a dual mass flywheel that is out of round, giving me a little "shake" (about 20% of the time)when I let the clutch out. How long can I let this go before I have to replace (with a single mass flywheel)? The clutch hooks up fine, no slipping. I only feel this "shake" at idle, not at speed. Am I going to damage anything if I let this "shaking" go?
Thank You
H2OFOWLER is offline
post #2 of 6 Old 10-29-2007, 03:27 PM
460+'s Avatar
If its shaking it could be on its way out,best plan on gettin one soon I'd say. Ive seen them like that when they come apart your done.
99 F350 4x4 dually
7.3 w/K&N af
4" exh into 6" Aussies stacks
4"lift &35" tires
CC mod HP crossover line
Beans stage II 120hp injectors
D66 turbo
ITP regulated return
reburn on TS= 25,high idle,60,100,120,140hp
updated ecm (2000 model)
Dyno#'s 360hp and 965 ft lbs trq
460+ is offline
post #3 of 6 Old 10-29-2007, 03:30 PM Thread Starter
OK, I'll plan on it. What will that cost me...roughly?
Thanks
post #4 of 6 Old 10-29-2007, 03:44 PM
460+'s Avatar
Depends on who you use, South Bend clutches are good but expensive,I think someone on the site said around $1000. I think they have aweb site you might check it out.
99 F350 4x4 dually
7.3 w/K&N af
4"lift &35" tires
D66 turbo
460+ is offline
post #5 of 6 Old 10-29-2007, 03:47 PM Thread Starter
Thanks 460+. SHould I just do the clutch at the same time, kinda makes sense I guess?
post #6 of 6 Old 10-29-2007, 07:35 PM
460+'s Avatar
Useualy the flywheel and clutch kit come together. Your welcome.
99 F350 4x4 dually
7.3 w/K&N af
4"lift &35" tires
D66 turbo
460+ is offline
