Super duty vcode spring q's - Ford Powerstroke Diesel Forum
post #1 of 5 Old 12-09-2012, 09:58 AM Thread Starter
olblue97's Avatar
What all is needed just saw my shackle and springs move 3 inches to either side while turning the wheel guess I can cancel out what is making the wobble at freeway speeds
Got a quote for new energy bushings 7 hours to install @100$ an hour found v code springs wih new bushings for 150!
So now that I'm done rambling my main question is do I get the vcode springs with the superduty shackles or is there more to this conversion
1994 F350 4x4 CCLBDRW
HID kit
front and rear captains chairs
full stereo flip out DVD
1995 cummins 12 valve (shhhh)
future mods
40 inch flush grill mounted LED lightbar
king ranch interior
front and rear HD bumpers
bronco fuel tank
olblue97 is offline
post #2 of 5 Old 12-09-2012, 11:07 AM
Delivers Pizzas For Fun!
ol_Blue97's Avatar
i had to double take this one..... will require a reverse shackle kit so the shackle is in the rear.. for the kit call Trevor at PMF! his kit is bolt on and doesn't require u to cut off your bumper bracket to run SD springs
FRANK THE TANK
DIY INTAKE - HYDRA CHIP - MARTY'S E-FUEL - 250/200s
05 AXLE SWAP 3.73 - 2.5" PURE PERF. LIFT COILS - FOX SHOCKS
BTS TRANS - TYMAR DOWN PIPE - 4" EXHAUST
Waiting To Be Installed... gtx4294r, studs, springs, HPOP?
Originally Posted by STROKED_NY_023 View Post
You are so smart Frank, I dont care what Terry says.
ol_Blue97 is offline
post #3 of 5 Old 12-09-2012, 02:40 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
wow same name almost, what frank said tho
be weird if both of yall were named frank lol
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #4 of 5 Old 12-09-2012, 03:17 PM Thread Starter
olblue97's Avatar
Will this cause any change in the front height of my truck because right now I have absolutly no rake and want to keep it that way
HID kit
future mods
king ranch interior
bronco fuel tank
olblue97 is offline
post #5 of 5 Old 12-10-2012, 10:59 AM
Quoted: 3 Post(s)
Feedback Score: 5 reviews
I developed this mod using SD springs and a RS kit 12-13 years ago and have helped thousands perform this mod. It will transform a OBS trucks ride. Actually will ride better than any stock SD
All RS kits will lift the front aprox 3" unless the wrong SD springs are used .. so just add F350 rear blocks to keep it level.
PM me if I can help.
CT Performance, Inc. is offline
