Replacing Engine Oil Cooler - Ford Powerstroke Diesel Forum
Old 12-09-2012, 06:42 AM
Anyone recommend a brand or website to buy the engine oil cooler for a 97 7.3L? It is leaking bad... Had oild all over the bottom of my truck and some made it on to my boat when I was towing it.
Old 12-09-2012, 03:42 PM
Most guys just replace the 4 large o rings and the two gaskets after pulling the cooler . The kit is around 70 bucks as opposed to 300.00 for complete cooler .You'll need to drain coolant and oil filter to remove cooler.It's not to bad a job,just a little messy .
Old 12-09-2012, 07:30 PM
Here ya go- Ford 7.3 Diesel Oil Cooler Repair Kit
Old 12-14-2012, 04:18 AM
When would you need to replace the whole oil cooler?
Old 12-14-2012, 05:49 AM
Not very often, maybe if you had some kind of damage and trash go through the oil system and were rebuilding the motor. The tube & shell type coolers are not that bad to clean out. Cheers!
Old 12-14-2012, 06:04 AM
7.3 4 Ever! Nothing else!
Feedback Score: 7 reviews
OEM!!!
