Red Brake light on - Ford Powerstroke Diesel Forum
post #1 of 18 Old 12-05-2012, 05:17 AM Thread Starter
tpndrcn's Avatar
Quoted: 2 Post(s)
Red Brake light on
My red brake light is on intermittently on my 96'own ccsb 7.3 when driving down the road. I unplugged the e-brake switch thinking this would eliminate the issue however the light came on again this morning. I checked the master cylinder level it is full and no leaks that i know of. There are no pedal issues whatsoever either. What are the next steps i should take to fix this? Forgot to add that when the light comes on it kicks off my cruise control. Also when I set the cruise I can feel a slight surge ,however it doesn't do this when not on cruise. Don't know if this is all related or not ,please help if you can.
Thanks Jesse
tpndrcn is offline
post #2 of 18 Old 12-05-2012, 07:08 AM
vandy's Avatar
Might Look at your vacuum lines. Low pressure will do this. Mine comes on on initial start up stays on till i start rolling. Kinda annoying but i haven't had time to chase it down
vandy is offline
post #3 of 18 Old 12-05-2012, 07:19 AM Thread Starter
tpndrcn's Avatar
Quoted: 2 Post(s)
Ok thanks I'll take a look at them ,any other ideas??
tpndrcn is offline
post #4 of 18 Old 12-05-2012, 07:26 AM
vandy's Avatar
Vaccum pump going out
vandy is offline
post #5 of 18 Old 12-05-2012, 09:42 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
vacuum pump possibly, good luck
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #6 of 18 Old 12-05-2012, 11:03 AM Thread Starter
tpndrcn's Avatar
Quoted: 2 Post(s)
Thanks for the input hopefully its not that but I will have to get a gauge on the pump and see. From what I have read you want it in the 15 to 25 range is that right??
tpndrcn is offline
post #7 of 18 Old 12-11-2012, 06:21 AM Thread Starter
tpndrcn's Avatar
Quoted: 2 Post(s)
BUMP!! I added the part about my cruise and wanted to see if that helped you guys with my diagnosis or is it still vacuum pump related?
tpndrcn is offline
post #8 of 18 Old 12-11-2012, 01:14 PM
kramarj's Avatar
I agree vacuum pump, might not go out today, but is probably on it's way out. Had the same problem in our work truck and the vacuum pump went out and as soon as it was replaced went off. Maybe something else, but I would think vacuum pump.
My Truck
97' F-250HD. ECLB. 66,000 miles. 7.3. E40D. 6637 Filter. 5" Exhaust. Deleted EBPV. CCV mod. 45 gal. Transferflow Rear Tank. Stock for now. Dana 60 in the works.
My Dad's
97' F-250HD. ECLB. 18x,xxx miles. 7.3. E40D. 6637 Filter. 4" Exhaust. TW Tunes. Work Truck.
97' F-250HD. ECLB. 150,000 miles. 7.3. E40D. 4" Exhaust. Work Truck.
kramarj is offline
post #9 of 18 Old 12-11-2012, 05:02 PM
dr.deere's Avatar
Quoted: 19 Post(s)
curious to find out what you find my brake light and abs light have been coming on intermittanly as well seems to me under harder braking been thinking about vacuum pump. haven't had time to look at yet
94 F-250 reg cab 4x4 5spd 7.3 stroke. 3inch downpipe, 4 in exhaust. super duty turbo with 1.0 non wastegated exhaust housing ww2 and 360 thrust kit. Intercooler, MB diesel hpop, driven diesel complete efuel, 6637 air filter, kingpin dana 60.
2012 f250 6.7l powerstroke crew cab long box
Note: The maximum size of your custom image is 500 by 100 pixels or 19.5 KB (whichever is smaller).
dr.deere is offline
post #10 of 18 Old 12-11-2012, 05:07 PM
Let us know what you find.... Mine has done this one time to me. I unplugged the ebrake switch and havent had an issue so far....?
2015 F-350 Lariat SRW CC
Sold to my dad:1996 F-350 XLT Crew Cab
2x4 Dually 7.3 with 80,000 miles as of 3-10-15
YJSONLY is offline
