Door cable replacement - Ford Powerstroke Diesel Forum
post #1 of 4 Old 12-02-2012, 07:24 PM Thread Starter
wysmith95's Avatar
Send a message via AIM to wysmith95
I have that famous problem of the door handles snapping off (no, not out of anger!) so I bought 2 new cables to go from the handle to the latch. I checked and my sheet metal is just fine inside the door, but I could not for the life of me figure out how to disconnect the old cable from the latch inside the door. Anyone else have any tips?
-Wyatt
'97 F350 CCLB Auto, 175k, still stock
'97 F250HD ECLB, 5Spd, 4 in straight pipe, gauges
wysmith95 is offline
post #2 of 4 Old 12-02-2012, 07:46 PM
kramarj's Avatar
It is a major PITA! At least the way I did it. I took the panel off and then the handle and the hinge/spring thing it's attached to. Then I took the latch itself out of the door after unhooking the lock. I have big hands and it was no fun. Maybe there is a better way to do it, but it kind of worked for me, I messed the lock up so now it won't lock, but at least the door opens.
My Truck
97' F-250HD. ECLB. 66,000 miles. 7.3. E40D. 6637 Filter. 5" Exhaust. Deleted EBPV. CCV mod. 45 gal. Transferflow Rear Tank. Stock for now. Dana 60 in the works.
My Dad's
97' F-250HD. ECLB. 18x,xxx miles. 7.3. E40D. 6637 Filter. 4" Exhaust. TW Tunes. Work Truck.
97' F-250HD. ECLB. 150,000 miles. 7.3. E40D. 4" Exhaust. Work Truck.
kramarj is offline
post #3 of 4 Old 12-03-2012, 07:17 AM Thread Starter
wysmith95's Avatar
If I knew I could reattach the lock without trouble, I wouldn't mind taking the latch out, but I'm in Reno quite often and do enjoy my stereo!
-Wyatt
post #4 of 4 Old 12-03-2012, 02:33 PM
kramarj's Avatar
Like I said, not sure if my way is the correct way, but I did get the cable changed. Maybe if you take your sweet time and take note of everything it would go better, I didn't really pay attention to how everything went together and it ended up the lock didn't work.
My Truck
My Dad's
kramarj is offline
