Dash light colors - Ford Powerstroke Diesel Forum
post #1 of 15 Old 12-01-2012, 03:10 AM Thread Starter
tpndrcn's Avatar
Quoted: 2 Post(s)
Dash light colors
Just installed an aftermarket cd/mp3 player I had laying around and it has primarily red background lighting. How hard is it to change the background lighting of my cluster so it matches??
tpndrcn is offline
post #2 of 15 Old 12-01-2012, 04:14 AM
powerstroke2501997's Avatar
Its not too bad, a little time consuming, I did it on my 97. The gauge cluster n the dash isn't bad, you have to change the bulbs and get the green backing off the back of the little black deals that your speedo n such. So you have to disassemble a pretty decent way
Sent from my C771 using AutoGuide.Com Free App
Tony
1997 F-250
ts-custom chip, intake, 5sp, 4-5" exhaust
powerstroke2501997 is offline
post #3 of 15 Old 12-04-2012, 08:55 PM
Electrical Ogre
alberta 7.3's Avatar
Quoted: 113 Post(s)
Yep, disassemble the cluster and remove the green paint. Either use colored lamps or LEDs, or re-paint with transparent hobby paint.
Bill
1996 F250 SC/SB 4X4 XLT
1997 F250 RC/SB 2WD project
2008 F350 CC/LB 4X4 DRW Lariat, 3" cow catcher mod
2008 Ranger SC FX4
Originally Posted by weareweird69 View Post
If your posting pictures bill, everyone dim their screens, that CAT YELLOW is bright
Originally Posted by Fordman247365 View Post
Is there anything you DONT take apart and **** with?
Originally Posted by JJFLASH View Post
I still say that those Dodge mirrors have as much business on a OBS Ford as yoga pants have on a fat chick...my .02
alberta 7.3 is offline
post #4 of 15 Old 12-05-2012, 11:05 AM Thread Starter
tpndrcn's Avatar
Quoted: 2 Post(s)
Looks good, the only thing I am hearing is its hard to change the HVAC controls also any word on that??
tpndrcn is offline
post #5 of 15 Old 12-05-2012, 03:43 PM
^x2 on that curious myself
Tony
1997 F-250
post #6 of 15 Old 12-05-2012, 03:56 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
should go exact same way bud, pull the knobs off take the plate off around your a/c controls pull the black thing off, but i couldnt see why you would want to scrape the blue or red off, those are obvious signs of what temp ya want it lol
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #7 of 15 Old 12-05-2012, 04:41 PM
...kind of looks homeless
marine5811's Avatar
^^^ x2 there. There are only three bulbs behind the HVAC controls. I have blue LEDs there and I should have just put white ones in for brightness and clarity.
Alex
1996 F350 --- D60, Warn Manual Hubs, RiffRaff 6637, 3" Diamond Eye Downpipe, TW Tunes, Gauges, Aeroforce Interceptor, JVC Head Unit w/ Bluetooth, Smoked Headlights, Blue LED dash, Factory RKE, Built Trans, TruCool Max, Black Interior In Progress
marine5811 is offline
post #8 of 15 Old 12-06-2012, 09:36 AM Thread Starter
tpndrcn's Avatar
Quoted: 2 Post(s)
Once again thanks for all the help out there and I will be more than willing to help when i come across similar problems with someone else
tpndrcn is offline
post #9 of 15 Old 12-06-2012, 01:09 PM
Nickd18's Avatar
What did you strip the paint with? I used laquer thinner on an old cluster i had and it didnt work very well..
Nickd18 is offline
post #10 of 15 Old 12-06-2012, 01:16 PM
marine5811's Avatar
I'm pretty sure Bill just scraped it off with back-strokes (away from the bladed edge) with a razor blade.
Alex
