Cut the 2 wires for the back pressure valve on the turbo pedestool. ground the black one and run the red one to a switch then from the switch to a power source like the hot on the battery. When i turn the switch on and i give it full throttle i lose some power and the exhaust sounds like a vacume cleaner but man does it ever smoke. U cant see anything at all behind u the smoke is that thick and black. The switch also acts as a exhaust brake when u let off the throttle which is nice too. Now i know therell be a lot of arguing on this post on why smoking is bad for the environment but just keep comments to urself. As soon as i make a video of how to do it and i figure out how to upload it on here then i will.
I'll tell you an even better way to make that 7.3 smoke. Stick a walmart bag (has to be a Walmart bag or it won't work) over your air intake and throw about 4 tires in the bed soaked with about 5 gallons of diesel fuel and set that beotch on FIA! All the black smoke you could ever want. Kid give your daddy his keys back along with his credit card and gtfo with this chit. Grow up moron, stupid azz threads and information like this from re
's like you are the EXACT reason that the EPA and CARB are DESTROYING this sport and diesel engines as a whole. And the fact that you even stated you were going to get flamed for your post Along with your still going to post a video of you doing this even proves that you have no right owning or driving a diesel powered anything.
In an attempt to save this thread before everyone wakes up and flames the hell outta this kid, ive gotta question. Growing up i remembered getting stuck behind an older diesel they would smoke like crazy pulling up hills. Ive never seen my rig smoke once. Why would my truck not? Have anything to do with the ULSD? I'm not complaining. Don't really want the smoke. Just wondering
Old diesels, even turbo ones, are non-feedback mechanical systems. Fuel delivery by an injection pump meant that the more throttle applied resulted in more fuel delivery. As the vehicle was driving through increased load, the resulting air charge would decrease but fuel delivery would not, resulting in less complete combustion of the fuel charge. Some mechanical diesels, such as the very elegant Mercedes 617 turbo, had an atmospheric compensation system called the ALDA system, as well as vacuum-fed fuel trimming that would try to adjust fuel charge under load. Guys like me, in the interests of power and as a byproduct get a little more coal, remove the tamper seal on the ALDA and trick the mechanical system into believing that atmospheric pressure is much higher than it really is... resulting in more fuel delivery under all conditions. Tailgaters can also be dealt with by stepping on the pedal repeatedly and not allowing the turbo lag to catch up to the extra fuel. EDIT: This is also why guys like my friend with a 91 12V have such an easy time getting coal... they can adjust delivery on their stock VE pumps quite easily [/EDIT] The only way to get the 7.3 to roll coal is to increase fuel delivery by way of programming. Stock, as well as most aftermarket tunes, will not have excess fuel... maybe a little bit more in tow tunes but I've only ever noticed a bit of coal when in tow mode and shifting to a higher gear under load. |
Do you have a manual or auto trans?
Also, did you upgrade your exhaust valve springs? I made my Samsung SGH-I997 send this. |
dude, go look on the 6.4 and 6.7 forums and see what they're having to deal with right now in terms of deletes for their engines because of stupid stuff like this. why do you WANT to be the guy with the p.o.s truck that has no power and runs more inefficiently than a beat up old carbd truck?? my trucks been having injector problems lately, its been smoking EVERYWHERE, just like what you're talking about. and you know what? its not cool, its embarressing...
Smoking needs to stay on the track. Not the streets. The EPA is hungry, and they know we have money. And they want it. sent from phone |
To the OP: GTFO of here Fag! |
I hope your joking!
My exact thoughts...... u do know that these engines have hydrolic lifters right??? When u close that valve it spikes your engine back pressures and then on top of that your dumb azz is flooring it and dumping fuel in the engine to send pressures even higher. This will lift your valves casing your lifter to float which when the cam comes back into its rotation it can bend the push rods, or piston to valve contact and brae valves, rockers, and push rods...... wait i forgot u just want to roll coal and don't care what it does to your engine! Next go round it will break and u will think that its junk because it did, but in reality u just shouldn't own a diesel if u cant respect it and maintain..... daddy must have bought that truck for u and pay to maintain it and fuel it, i know i cant afford those bills.
