E4OD takes off in 2nd gear? - Ford Powerstroke Diesel Forum
post #1 of 7 Old 11-29-2012, 01:44 PM Thread Starter
mikesuperduty's Avatar
I have had my 97 cc psd for over 2 years and didn't know it will take off in 2nd untill my 17 year old son asked me if it will. He said its an E4OD feature so I had to check it out.
The first thing I noticed is shifting from park to drive I feel it engage first then, still not moving shift to 2nd and feel it shift to 2nd.
It takes off much smoother without spinning so I think it will be nice this winter.
I did some searching but didn't find any details just bad trans stuff.
Is this a hidden secret?
mikesuperduty is offline
post #2 of 7 Old 11-29-2012, 01:47 PM
Don't you worry about it
strokinpower's Avatar
Quoted: 270 Post(s)
I'm pretty sure all cars do that...
2014 Platipus
AP Intake
Spartan EZLYNK
4" Dual Exhaust
4" BDS with Fox shocks and PMF stage 2 traction blocks
strokinpower is offline
post #3 of 7 Old 11-29-2012, 02:54 PM
PoppaSmurff's Avatar
This is a trait of the the automatics. You can start in second gear to reduce torque to the rear wheels in a slippery situation, and then if your still getting the one wheel spin you can slowly apply your parking break to increase drag on your drive wheel and force engagement of the wheel thats not spinning. Just another old school driving tip!!
'95 7.3 crew cab, Dyna 60 fnt/60 rear
E4OD Auto Slush-box
6 Pos. TS chip,
3" turbo oulet/down pipe,
twin 5" stacks,
custom 1/4" plate winch bumper
w/12000lb Hyd. winch,
3 guage A piller cluster,
Banks 1.00 turbine houseing and compressor wheel,
T-500 HPOP,
DIY 50+HP injectors,
High Pressure Oil X-Flow line,
Hadley air horns and air comp.
PoppaSmurff is offline
post #4 of 7 Old 11-30-2012, 12:59 PM Thread Starter
Everything I've had (mostly chevys) would start off in first no matter what but I think it will be useful.
Now I'd like to figure out how the trans computer works and why it shifts to OD at 35 mph sometimes for 100-200 feet then back to third. Also how I can get the T/C to lock sooner when It's cold.
post #5 of 7 Old 11-30-2012, 01:30 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
it does that because it is trying to optomize its economy ratings, and does not feel a load but then instantly feels drag again and shifts back to 3rd
make a TC lock up switch lol
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #6 of 7 Old 11-30-2012, 06:10 PM Thread Starter
I would like to have a TC lockup switch but I'm afraid to do that mod
post #7 of 7 Old 11-30-2012, 08:05 PM
Quoted: 77 Post(s)
The computer does not allow lockup until the trans reach's a preset temp. A custom burned chip can change when and how the trans shifts including when it shifts into od. The trans taking off in second is just manually overriding the computer.
Jack
97 F250 Xlt, built E4od, D60 swap, Baby swamps, tunes by Dp
1.0 housing w/ wwII, 203* t-stat, diy 6637, 4" exhaust
Diy intercooled, 6.0 fan, Diy 140v Idm, Isspro Ev gauges
On board air, E-fuel, 6" lift on 35's
322000 miles
1Dieselman is offline
