Rough country lift question? - Ford Powerstroke Diesel Forum
post #1 of 6 Old 11-29-2012, 10:17 AM Thread Starter
my 97 f350 has 4" blocks in the rear and im looking into doin a 4" lift...
Id like to do springs all the way round but i probly will end up with blocks in the rear cause of price... My question is are you sussposed to stack the 4" factory block and the 3"rc block because that seems sketchy... but the istallation directions say too do it???? Has any one done that and is it safe. I might just do the sky rsk on the rear... but havent decided yet.
obs97stroker is offline
post #2 of 6 Old 11-29-2012, 10:36 AM
erics diesel's Avatar
Personally I would get the right size block and not stack them
95 f250 eclb 4x4 under construction
96 f250 eclb 4x4 rosewood stage 1 injectors, bully dog 6 position chip, 6637 air filter, idm mod
erics diesel is offline
post #3 of 6 Old 11-29-2012, 10:38 AM Thread Starter
Yeah that seems like a better option... i wonder if they even make 7" blocks ill try to find out tho.
post #4 of 6 Old 11-29-2012, 12:30 PM
Quoted: 77 Post(s)
Feedback Score: 4 reviews
How much lower is the front end compared to the back. If the front is more than 2" lower than the back you may be able to go with a 5" block and the truck will sit fairly level. If you go with a block taller than 5" you will most likely end up with a axle wrap problem.
Jack
97 F250 Xlt, built E4od, D60 swap, Baby swamps, tunes by Dp
1.0 housing w/ wwII, 203* t-stat, diy 6637, 4" exhaust
Diy intercooled, 6.0 fan, Diy 140v Idm, Isspro Ev gauges
On board air, E-fuel, 6" lift on 35's
322000 miles
1Dieselman is offline
post #5 of 6 Old 11-29-2012, 06:24 PM
dazed01's Avatar
Traction blocks from pmf work well.
Gun control is like trying to reduce drunk driving by making it tougher for sober people to own cars.
dazed01 is offline
post #6 of 6 Old 11-30-2012, 10:16 AM
Quoted: 3 Post(s)
Feedback Score: 5 reviews
If you want a 4" lift and not have it ride like a tank we have been doing the RS-SD spring swaps for over 12 years..have everythng needed.
CT Performance, Inc. is offline
