7.3 high idle controller - Ford Powerstroke Diesel Forum
Old 11-26-2012, 12:51 PM
What is a Ford high idle controller new in box for a 7.3 worth?
Sent from my SAMSUNG-Galaxy SII Skyrocket using AutoGuide.Com Free App
Old 11-26-2012, 02:22 PM
Delivers Pizzas For Fun!
Idk but u can get an aftermarket setup from defuser for under 100.... 70 is ringing a bell and looks like a ts chip knob
Old 11-26-2012, 02:25 PM
What is a high idle good for?
Old 11-26-2012, 02:32 PM
Warming it up, use it when jumping another car, anytime u need a little rpm when loading the engine down, dump bed, winch,...... controll speed in 4 low while towing something across a field, the ford one wont work in drive i dont think.
Old 11-26-2012, 02:39 PM
Ok that is what I thought. I knew some of those but learned a few more uses too.
Old 11-26-2012, 02:56 PM
Ive never done the towing thing, but have wished i had it to match the speed of a tractor b4 while doing hay in other trucks.
My grandpa had a hand throttle on a model t they used as a potato truck. They would lock the hand throttle in, hop out, and walk behind it throwing the potatoes in while the truck drove itself.
Old 11-26-2012, 04:48 PM
I picked up a a ford unit today that has never been used. Don't have the instructions though on how to install or use it though. Can anyone input on this? My truck is a 95 5 speed.
Old 11-27-2012, 03:02 AM
Should be a plug in cord located center dash down below by the heater outlet, found mine tucked up behind the heater controls. 4 pin connector if I recall, snap it together, powers up automatically, then slightly depress the emergency brake and it will idle up, if your glow plugs are still on she'll idle up to around 2 grand and once the plugs go off she'll idle back to around 11, least thats what my truck does, if you touch the ebrake, regular brake, or drop it in gear on an auto it will immediately shut down the controller and resume normal idle.. Oh I got mine on Ebay 75 bucks.....
Slick
Old 11-27-2012, 08:39 AM
...kind of looks homeless
PM me your email address and I'll email you the user manual. I don't have one, but I did stumble across the user manual about a year ago online and saved it.
Old 11-27-2012, 03:31 PM
Thanks yo slick. And Marine, I found the manual online. Just gotta find the plug now. Thanks guys .
