removing ball joints PITA! - Ford Powerstroke Diesel Forum
post #1 of 14 Old 11-23-2012, 01:07 PM Thread Starter
i bought an old pair of knuckles and im trying to remove the old ball joints but i am getting nowhere. there is corrosion on the knuckle, ( i bought it from up north) but i have heated and even broke my vise while i was torquing away with the ball joint press. no go. I tried my old knuckle just to see if i was doing it right and it popped right out.
anyone ever have some stubborn a$$ ball joints with a secret
fstfrd01 is offline
post #2 of 14 Old 11-23-2012, 01:19 PM
rolsmojave3's Avatar
You need a ball joint press
1997 Ford F-350 4x4 SRW regular cab manual trans.
-4.10s, 315/75r16...getting a frame off restoration. Go fast stuff
1996 Ford F-350 4x4 SRW CCLB manual trans. CALI spec
-ATS intercooler, WW2 w/ 1.0 housing/EPBV delete, Comp 910s, SD Efuel, 3.55s, 315/75r16
2002 Ranger FX4 with manual transfer case and Alcoa's
rolsmojave3 is offline
post #3 of 14 Old 11-23-2012, 01:38 PM Thread Starter
im using a ball joint press
fstfrd01 is offline
post #4 of 14 Old 11-23-2012, 01:50 PM
Diesel_brad's Avatar
Quoted: 4 Post(s)
Lube is your friend and a LIL heat goes a long way
Looking for Blue 40-20-40 seats. PM me !!!!!!!
Diesel_brad is offline
post #5 of 14 Old 11-23-2012, 02:02 PM Thread Starter
more lube than you know and more heat than i than ive ever used...no luck
fstfrd01 is offline
post #6 of 14 Old 11-23-2012, 02:39 PM
APEX 06's Avatar
Use a impact on the ball joint press. Seen it done on youtube and it works good.
Sent from the can!
2008 F250 Lariat 4 Door Crew Cab, H&S Minn Maxx S&B intake, sinister coolent filter
APEX 06 is offline
post #7 of 14 Old 11-23-2012, 02:48 PM
Quoted: 4 Post(s)
Too much heat is NO GOOD. all you do there is swell EVERYTHING and make a even tighter fit
post #8 of 14 Old 11-23-2012, 02:59 PM
ZMANN's Avatar
Quoted: 1566 Post(s)
agreed heat in the right place works to expand and open the orifice
don't heat the ball joint at all .....try to heat the knuckle only
We Miss you Ronnie
ZMANN is offline
post #9 of 14 Old 11-23-2012, 06:22 PM Thread Starter
yes i was heating the knuckle only, not the ball joint. i think im going to try some dry ice on the ball joinbt and heat the nuckle next
fstfrd01 is offline
post #10 of 14 Old 11-24-2012, 12:18 PM
dazed01's Avatar
I've found on things stuck like that using the press and while you have pressure on the part you are trying to remove, hit the surrounding part repeatedly with a hammer. It works almost every time. It doesn't have to be a big hammer, just enough to get the parts moving a bit.
Gun control is like trying to reduce drunk driving by making it tougher for sober people to own cars.
dazed01 is offline
