towing with a rear shackle flip?
Anybody tow regularly with a rear shackle flip?
i am planning a shackle reversal in the front of my truck and would like to ditch the stock 4" blocks in the back but i don't know how well the shackle flips work in these F-350s, its what i used in my Bronco and they worked great. just want some opinions, thanks. |
the only ones ive seen seem to move you axle forward a bit and looks off center, why do u want to get rid of blocks?
don't like axle wrap and am trying to avoid building traction bars.
What about using lift springs? What size blocks do u have.....
Next question, is it axle wrap or a drive shaft issue with center carrier bearing needing shimmed or replaced. I got traction bars for that same issue, installed them and issue was still there and was like WTF!.... now i know what the issue is |
no i already shimmed the carrier bearing and it definatly helped, i can't believe the previous owner drove it like that, but i just have a prejudice against lift blocks and would prefer not to have them.
lift springs would work too but are significantly more expensive than a shackle flip. |
that they are, call up SKY and ask them, i dont know of any other manufacturer so i dont know who your using
I won't sell a shackle flip for the street.............
why not? i run one in my Bronco and it works great.
I run the shackle flip and never had a issue. I tow quite a bit and Ive towed pretty heavy. Truck drives great. Never had a issue
