More Boost? - Ford Powerstroke Diesel Forum
Old 11-14-2012, 07:11 AM
More Boost?
What does it take?
Old 11-14-2012, 08:03 AM
More fuel. No exhaust leaks between the manifolds and turbo and no air leaks between the turbo and heads.
Old 11-14-2012, 08:05 AM
Thanks for the response. what about the lag?
Old 11-14-2012, 08:18 AM
Are you using any kind of a chip. The combination of lag and high elevations (which makes it worse) is why I installed a fast spool housing.
Old 11-14-2012, 08:22 AM
Yes, 6 position TS
Old 11-14-2012, 08:27 AM
What other mods do you have and how much boost are you making?
Old 11-14-2012, 08:33 AM
I should probably fill out my signature out.LOL
Intake 6637
3’’ downpipe straight piped
HPX riffraff
Stancore GPR
RSK
Lighted visors
Grab handles
EV’2 gauges
I have all the components to do my intercooler just not done yet (TIME)
There may be more just can’t remember.
20lbs of boost
Old 11-14-2012, 08:58 AM
I think you should see about 5 lbs or so more boost than that. I would get right at 27lbs before my intercooler install. After the intercooler install the highest boost I've seen is about 24lbs. I am curious to see what it will be when I get around to upgrading injectors.
Old 11-14-2012, 09:05 AM
Since the EV’2 use a boost sensor and not the typical tubing, I wonder if it is just more accurate or not?
Old 11-14-2012, 10:00 AM
Honestly don't know. Mine was measured with to different mechanical gauges and got the same reading.
