Manual locking hubs
I'm putting u joints in a 97 f250 at work and I went to put the lockers back in the internals came out if the one. Ordered a new set and tried putting them in but they won't go in far enough to get the lock ring in place. I pulled it out and put the old one back on with no problem at all so I know I put everything else on correctly. Anyone ever have this problem?
The hubs I bought at Warn part number 11690 |
Did you swap from automatic lockouts to manual? If so the nut is different. IIRC it's a 4 spline nut that you need for the manual lockouts.
If you get the nuts for manual hubs I might be interested in your auto nuts if there in good shape
Sent from my SCH-I500 using AutoGuide.Com Free App |
Also oreillys can get the manual nut sets for around 38 bucks each
It already had the manual conversion on it. I ended up calling warn and he said to take the inner snap ring and 3 washers off and it fit after that
