oil pan leak - Ford Powerstroke Diesel Forum
Old 11-11-2012, 02:16 PM
oil pan leak
i have a 1996 f350 7.3 an the oil pan is leaking does any one have any ideas no time to pull the motor right now to reseal her thanks for ANY advice
Old 11-11-2012, 02:51 PM
Your gonna have to pull the motor or at least jack it up I think.
Old 11-11-2012, 03:18 PM
Sure it's the pan and not something else?
Old 11-11-2012, 03:28 PM
Illiana Chapter Director
Strictly Diesel Dipstick Adapter Repair Kit
Old 11-11-2012, 06:04 PM
yea I'm positive passenger side rear corner
Old 11-11-2012, 06:15 PM
I don't know why I assumed it was coming from the dipstick
Old 11-12-2012, 05:20 PM
my pan was leaking slightly in the front. i cleaned up oil with brake clean and smeared some of the grey silicone ford uses for a pan seal on the 7.3 in the joint. let set up for a couple hours and leak solved cuz i also had not time to pull motor until spring.
Old 11-14-2012, 11:38 AM
I spent a week fixing mine after i drained the oil i let it sit for three days then brake cleaned the piss out of it. after it was fully done dripping and drying i placed a good amount of jb weld on the leaking area then took a shop paper towel, and stuck it to the jbweld. I took another layer of jbweld over top of that making a jb weld, carbon fiber. and to this day it still holds that was a year and a half ago. not a drop of oil leaks out of it.
