Sterling 10.25" limited slip - Ford Powerstroke Diesel Forum
Old 11-10-2012, 05:03 AM
How's the limited slip setup in a 10.25? The same way as an 8.8? The diff. Tags are labeled 4.10L so its definitely a limited slip diff. I literally for it stuck in wet grass the other day with a one tire fire and had to pull it up in 4 wheel drive lol
Sent from my DROID2 GLOBAL using AutoGuide App
Old 11-10-2012, 06:06 AM
When's the last time the fluid was changed and friction modifier added?
Old 11-10-2012, 06:20 AM
I have no idea...I just picked it up in august from some old timer lol
Old 11-10-2012, 06:29 AM
Delivers Pizzas For Fun!
They wear out pretty fast and arent too effective... tru trac install comming up???
Old 11-10-2012, 08:58 AM
Negative ghost rider....I have other items to rake care of first lol
Old 11-10-2012, 02:14 PM
the baconator
just cause it says 410L doesn't mean that it is. jack it up and spin one wheel do both move? then yes it is a limited slip.
i have a 97 that says C9 (3.55 LS) and has a tag 3.55L on the diff i opened it up the other day and it was an open diff
