What is this?? - Ford Powerstroke Diesel Forum
post #1 of 6 Old 11-08-2012, 06:05 PM Thread Starter
EflumE's Avatar
Quoted: 30 Post(s)
What is this??
I decided to clean the FPR screen today... yes, i dropped the screen into the valley. I took out my trusty telescoping magnet and, after quite some time of blindly fishing around, had no luck getting the screen back. However, i did pull this little guy out.
Any ideas what it is???
Another question.... Will my truck be okay running it without the screen for a bit? The parts are ordered but won't be here until next week.
Thanks,
Name:	2012-11-07 10.06.45.jpg
ID:	45440   Click image for larger version
Name:	2012-11-07 10.11.42.jpg
-Eric-
96 cclb, baby swamps, TS 6 position w/swamp's tunes, billet wheel, 1.0 housing, diy ebpv delete w/plugged pedestal, 3" downpipe to 4" exhaust, 6637, boost, egt, trans gauge, fully built trans, 203* tstat, 08 diff cover, airlift helper springs
218,000
9 inch skyjacker on 37" interco M16's
EflumE is offline
post #2 of 6 Old 11-08-2012, 07:07 PM
glovemeister's Avatar
It should be fine, but when I was in Ace Hardware/ True value a couple days ago I happened to notice they stocked sink screens. It would probably work just the same.
glovemeister is offline
post #3 of 6 Old 11-08-2012, 08:59 PM
desertdeer's Avatar
that deal you found is a part off the ipr. was probably replaced at one time and that piece dropped in.
96 F250 PSD 3''DP 4'' ATS EXHAUST 6637 TS-6 5-SPEED LUK CONVERSION INTERCOOLER PROPANE 4'' LIFT 35X18'S
desertdeer is offline
post #4 of 6 Old 11-09-2012, 03:29 AM Thread Starter
EflumE's Avatar
Quoted: 30 Post(s)
Thanks guys
I heard a lot of people using the sink screens. Thought about it but found the screen and the O-rings for twenty bucks so I figured I'd stick with the real parts.
So no worries about the part? That was a PO job.
I'm still convinced if we all looked hard enough we would find small animals and possibly the map to the fountain of youth in the valley
-Eric-
218,000
EflumE is offline
post #5 of 6 Old 11-09-2012, 03:32 AM Thread Starter
EflumE's Avatar
Quoted: 30 Post(s)
^^^ and an fpr screen!!
-Eric-
218,000
EflumE is offline
post #6 of 6 Old 11-09-2012, 10:53 AM
Quoted: 50 Post(s)
Found a mouse nest, made from insulation stolen from our basement no doubt, in the valley of the RCLB the other day.
madpogue is offline
