The rattles!!!!!!!!!!!!!!!!!!! - Ford Powerstroke Diesel Forum
post #1 of 7 Old 11-08-2012, 02:13 PM Thread Starter
vandy's Avatar
what do you do to get rid of all the rattles? i dont have many, most will be fixed with new door bushings. but the rear drivers side door pannel is driving me insane.
what tricks of the trade do yall have to get rid of the squeeks/rattles?
vandy is offline
post #2 of 7 Old 11-08-2012, 02:30 PM
BANNED by Kris
BigFuel's Avatar
Quoted: 40 Post(s)
If it's metal on metal I'll work some Anti-Sieze between the parts.
Matt
'97
-Bean's: 160/100 (FF Injectors), 2/ 6-POS chips (TW & Beans tunes), Overboost controller, E-Fuel
-BANKs: downpipe, full exhaust, gauges, intercooler
-Irate: T-4 kit, IC pipes, 3" Irate Plenums, BASB Turbo
-Stage II trans.
-Mag-Hytec trans. and pumpkin covers
-6637, CCV, IDM, 6.0 Fan, 49-Federal PCM swap, MAP line Mod
-370 Amp alt., 40k trans cooler, ADRENALINE PUMP
-twin on-board air w/ 10 gal. tank
-Oh, and a 2015 F350 6.7L DRW 4x4
BigFuel is offline
post #3 of 7 Old 11-08-2012, 03:05 PM
boozinag's Avatar
My dash creaks every time I hit a bump. I am hoping the D60/SD RSK fixes some of that.
Gerry
'97 CCSB f-250 4x4 auto, 6pos chip w/ canned tunes, AFE intake, 4 in exhaust, 3in dp, 3.55 gears,
Dana 60 rebuilt and waiting to be installed
184k
boozinag is offline
post #4 of 7 Old 11-08-2012, 03:06 PM
Delivers Pizzas For Fun!
ol_Blue97's Avatar
I hear replacing the push pins will help with the squeeks... my pass side door panel squeeks a lot but the driver that has new push pins does not... so there may be some truth to it
FRANK THE TANK
DIY INTAKE - HYDRA CHIP - MARTY'S E-FUEL - 250/200s
05 AXLE SWAP 3.73 - 2.5" PURE PERF. LIFT COILS - FOX SHOCKS
BTS TRANS - TYMAR DOWN PIPE - 4" EXHAUST
Waiting To Be Installed... gtx4294r, studs, springs, HPOP?
Originally Posted by STROKED_NY_023 View Post
You are so smart Frank, I dont care what Terry says.
ol_Blue97 is offline
post #5 of 7 Old 11-08-2012, 03:56 PM
BANNED by Kris
BigFuel's Avatar
Quoted: 40 Post(s)
vandy, are all the screws in the door still?
Matt
'97
-Stage II trans.
BigFuel is offline
post #6 of 7 Old 11-09-2012, 03:55 AM
E55 Bulldog's Avatar
Quoted: 3 Post(s)
My doors were rattling and squeeking so i replaced the Door Strikers, there were $8 at advanced auto parts. The plastic sleeves were either broken or cracked so it causedore stress on the hinges while the door was shut. Id try that first, its a quick, easy, and cheap fix.
1995 C350 Centurion - 4 Door Bronco
7.3 Powerstroke
4" BDS Lift w/ Fox Shocks
3" DP, 5" Straight Exhaust
1997 Ford Frankenstein CCSB: SOLD
4.25 RSK w/ Rough Country Shocks
Dana60 King-Pin Front / Dana80 Rear / 4:10 Gears /
MT Classic Lock w/ 35” Toyo Open Country MT
E40d w/ Banks Triple Disk Torque Converter and
3”dp w/ muffler and cat delete to 5” Stacks
Ranch Hand Rear Bumper
E55 Bulldog is offline
post #7 of 7 Old 11-09-2012, 04:46 AM Thread Starter
vandy's Avatar
The push pins are new. I think maybe one was good when i pulled the door panels for my tint.
Ill have to check the screws on the door sill
The door pins are wore out. I can lift all 4 of the doors about a half inch. I put plastic striker bushings on when i bought it and that helped a lot. Almost sounds like the lock rod moving around.
I think pins and bushings will help more than anything
vandy is offline
