Shuttering @ 45-50mph
Truck has 183,000 miles & it's bone stock.
I jsut added new fuel lines, filter, FPR Shim, no fuel pressure guage. I've been meaing to add it since I shimmed it, but havent had time. After all this work, I get on the Parkway to go to work and the first time it did it, I thought the shuttering was the bumpy road. Then it kept doing it until I added or removed throttle. It now does it at 45-50 mph constantly. It SOUNDS like it is running fine, and doesnt seem to have any sort of loss in power; even when I get on it. I dont remember if my truck shuttered before I shimmed it. Sounds like fuel delivery, right? Fuel pump? Thanks in advance for any suggestions or input! Cheers! |
Have you run it enough to get any air out of the system?
Yeah, I've put over 4,000 miles on it since the tune-up.
It does it around 45-50 mph, 1200 RPM. I was thinking tires, but wouldnt the vibe change with speed? This changes with variations of the throttle. |
Check the balance of your tires, that 40-60mph zone us the key shake zone fir and off balance. You might not feel it as much when the engine is being throttles since these engine vibrate a lot too
Just put new tires and shocks on it. WOW! What a difference.
The old tires didn't LOOK bad, but they must have had a blown cord or two. That thing got violent yesterday on the way to the shop. Thanks for the help gents! |
