zf5-zf6 swap
how hard would this swap be? Really need a 6th gear lol.
Well, first off overdrive gear in both is about the same ratio just the ZF6 has a much lower first gear. I have driven several ZF6 speed trucks and unless you are towing heavy in the hills first gear is rarely used. If you still want to swap you need a different clutch disc, your transfer case will not fit so then when you use the superduty transfer case your driveshafts won't fit, will need the trans cooler and lines and I believe a different clutch slave cylinder.
Soo.. realistically. Not worth it...? Just so high of rpms at 70 and at 3lbs of boost.
Realistically, no because overdrive ratio will not change. What gear ratio and size tire are you running? What rpm's are you turning at 70?
subbed for info...70 with 4.10's is not fun IMO
the zf6 has a slightly lower OD and not as far of a gap between the 3-4 shift.. let me see if i can find numbers
EDIT.....let me try to find numbers from ZF and not off a forum, but here they are The ratios for the ZF6 are as follows: Low gear 5.79 1st gear 3.30 2nd gear 2.10 3rd gear 1.31 4th gear 1.00 overdrive 0.72 The S5-42 IDI trans 1st Gear: 4.14 2nd Gear: 2.37 3rd Gear: 1.42 4th Gear: 1.00 5th Gear: 0.77 The S5-47 95-97 trans is 1st Gear: 5.08 2nd Gear: 2.60 3rd Gear: 1.53 4th Gear: 1.00 5th Gear: 0.77 And the wide ratio version of both is: 1st Gear: 5.72 2nd Gear: 2.94 3rd Gear: 1.61 4th Gear: 1.00 5th Gear: 0.76 edit... conflicting info 1st = 5.79, 2nd = 3.31, 3rd = 2.10, 4th = 1.31, 5th = 1.00, 6th = 0.76 Reverse = 5.23 Last edited by ol_Blue97; 11-07-2012 at 07:55 AM. |
i have both and i agree low is pretty much useless. and you will need a different trans cross member.
i also have 4.10s and have no issues, then again i almost never hit 70 |
Not to steal the thread but how about changing the diffs to 3.73? I drove a 5 speed the other day with 4.10 and at 70 i was at 2500 rpm. My 2x4 with 3.55 sits at 2300rpm at 85. I was thinking about doing a gear swap had I bought the truck. And what would you be looking at rpm wise with 3.73s? at 70?
I wonder how a zf6 would be with 3.55s and 35s or similar... that low to first shift is difficult on the 6 speed tho..
and frank that shift is not easy and pulling hills with 3.73 weight in at 20K+ lbs is not fun either the phrase no balls comes to mind. i really wish that dump truck had 4.10s |
