SD axle dimensions? (D60 swap question) - Ford Powerstroke Diesel Forum
Old 11-05-2012, 12:48 PM
Been looking for a D60 to swap into my 95 F250 for a while now. All the axles for our OBS trucks are 1k and up, for just the fronts, which I feel is a bit pricey. However, I have found a set of '00 SD 60's out of a f350 SD, for 750 for the set. Between me and my buddy I have all the know-how/equipment to customize it to fit, but I wanna get an accurate picture of how much work I'm setting myself up for. I believe I would need new rims(different lug pattern, IIRC?), would I need anything else if i grab the complete axle(calipers, springs, etc? Also does anyone have the OBS bracket dimensions so I can could figure out where i need to move the perches and whatnot? Thanks guys
PS. Im doing the rsk/SD spring swap while I'm at it, if that changes it at all
Old 11-05-2012, 01:27 PM
the baconator
that axle is a straight axle d50, the rear is a direct bolt in, the front has slightly wider spring perches. the bolt patterns are different. i'm sure someone with more info can help you out more
Old 11-05-2012, 01:31 PM
Delivers Pizzas For Fun!
i believe Cary at CT Performance sells a RSK kit to covert to SD axles and springs. which is different then the SD spring RSK for an OBS D60..
also a custom track bar bracket will needed to be installed. and u joints are different, will require custom drive shaft or adapter joint. 1350-to-1410
Old 11-05-2012, 01:53 PM
the baconator
i bleieve the u joints at least for the rear axle are the same. at least the one i had was, but it was a from an E99 and they were a bastard axle
Old 11-05-2012, 01:55 PM
??? could be, i thought all SD joints were 1410's maybe just 05+
Old 11-05-2012, 02:06 PM
It is? I thought f250 had the d50 and f350 had the actual d60
Sent from my iPhone using Autoguide.com App
Old 11-05-2012, 02:09 PM
the baconator
nope the SDs from 99+ - 02 had D50 in SRW and D60s in DRW starting in 02 all trucks had D60s. the one way to check in the pinion nut. a D50 has a 1 1/8 and the D60 has a 1 5/16
Old 11-05-2012, 02:11 PM
this is correct for the 1997 and older trucks
Old 11-06-2012, 11:00 AM
Hmmm...in that case what you guys think bout a 03+ axle and just completely rework the mounting locations? or are the driveline angles different and whatnot?
Old 11-06-2012, 01:14 PM
the baconator
cal cary at CTPerformance. he is the man when it comes to these swaps
