Thanks guys!
We have everything needed to put any OBS to '11 axles and suspension in these trucks... |
What gear ratio do you need?
What ratio do I need? I'm actually thinkin 3.73 might be perfect, 3.55 has nowhere near enough balls for how I use my trucks, but 4.10 makes the rpms howl goin down the highway(unless I go with 37's, hmmmm...)
Sent from my iPhone using Autoguide.com App |
Thanks Cary ill give you a call. I actually talked to you a couple months ago bout the rsk swap for an OBS D60
3.73 work great even towing IF you got HP...I have 450HP by turning the chip up so can use the HP for short bursts passing if needed. But if I had my choice I'd have 4.10's runing 35" tires. 7.3's at 2000rpm @70+- is perfect.
They like to be at 2300-2500rpm in the mountains towing.. |
^Agreed on Cary's engine power math. Our engines like to hum and cruise with a load above 2000rpm. With my hauling needs it is looking more and more like I need a second truck (and win the lottery) so that I could dump it and Cary's and pick it up in a couple months with everything I want to have fun.
You just need this...http://www.powerstroke.org/forum/tru...-sc-built.html
Yes I do but not the financing to go with it
maybe its my tired injectors
That is true, above 2k RPM the fuel gauge starts to move rather quickly.
