1995 F350 T-case fill question - Ford Powerstroke Diesel Forum
post #1 of 2 Old 11-04-2012, 04:55 PM Thread Starter
On the Borg Warner t-case, is there a trick to filling it? (As in, do you need to snake a hose way in there, or just get the fluid in right at the fill hole?) I ask because the t-case seems to be leaking fluid all over the garage floor, yet when I try to add fluid through the fill hole it barely takes any before running back out. And the transmission (ZF5) fluid is full, so I think it has to be coming from the transfer case. Any ideas? The attached photo is the view looking down toward the fill hole.
EHD1 is offline
post #2 of 2 Old 11-04-2012, 06:49 PM
kramarj's Avatar
I just changed to fluid in our work truck and I used a suction gun, it is a lincoln, looks kind of like a grease gun, but a suction gun(at least that is what I call it). It was a bit messy, but it worked.
My Truck
97' F-250HD. ECLB. 66,000 miles. 7.3. E40D. 6637 Filter. 5" Exhaust. Deleted EBPV. CCV mod. 45 gal. Transferflow Rear Tank. Stock for now. Dana 60 in the works.
My Dad's
97' F-250HD. ECLB. 18x,xxx miles. 7.3. E40D. 6637 Filter. 4" Exhaust. TW Tunes. Work Truck.
97' F-250HD. ECLB. 150,000 miles. 7.3. E40D. 4" Exhaust. Work Truck.
kramarj is offline
