Completely Reseal
Okay everyone, I want to completely reseal my engine... I mean everything. I am talking piston rings, hpop rings, crankcase, turbo, heck! Even the oil drain seal. I want to reseal the tranny also, how much do you all think this will cost? Where can I buy all of this? I am in school right now, but once I get out I am going to buy a beater just to get around and pull my engine. I want to make this truck bulletproof. She isn't leaking too bad right now, but I am burning up oil from the piston rings going out. I'm talking a couple quarts every thousand miles. Any help is appreciated!
Sent from my iPhone using Autoguide |
How many miles? When a stroke burns oil you can usually fix it with injector o-rings. If the piston rings are shot then you are looking at a rebuild
Why would you go through the trouble of pulling the pistons and rods out and not replace the bearings, your right there, and entire rebuild kit can be got for $1200-$1400 and has everything you will need to "reseal" your engine, plus new pistons, bearings
With 180k on the engine unless it has been severely abused I wouldn't pull the engine to install piston rings or anything else for that matter. You can't just pull pistons, and install new rings. At minimum the cylinders will need to be honed and checked for roundness and taper which means pulling the crank or the first time you start it you will be shortening the life of the bearings from all the honing grit. You cannot install new rings in a less than perfect cylinder and expect them to seal, ever! I would just fix any external leaks, check the turbo, and go down the road with it.
Try running some atf in the fuel to free up any rings that may be stuck from it sitting for so long
Does the blow by go away when you raise the rpm's off of idle? I would check the exhaust side of the turbo to see if it is oily, wiped out turbo seals will go through a lot of oil. I would also do a compression and or leak down test before determining that the engine is hurt.
Sent from my iPhone using Autoguide.com App |
