Trailer Wiring. Who knows it? - Ford Powerstroke Diesel Forum
post #1 of 13 Old 11-04-2012, 09:44 AM Thread Starter
POWERSMOKIN's Avatar
So a couple of months ago (I seldom tow trailers) I noticed that i had no running lights on my trailer harness. Brake, turn hazard worked just fine. I figured I wouldnt mess with it, because it was like -20*F and blowing like 30MPH..
But now that I have extra time, I figured that I would.
Im no stranger to electrical systems, but thought i would check here first to see if anyone has done trailer wiring.
Basically, is there anywhere that ford so nicely puts hook-ups for trailer wiring? Or do these shops just t-tap the hell out of everything?
My connector is just rusted to hell, and out of the 7 pins there, only 4 have wires exist on the connector -_- so I was figuring that i would fix it, and update it as well, with all new wiring (so all 7 are connected) and a new connector.
~Mike Lewis
1996 F-350 CC LB PSD
Beans Stage 1's - 6637 Intake - SD HPOP - 5" Exhaust
E4OD w/ Shift Kit - Sky MFG Reverse Shackle
265,000MI
POWERSMOKIN is offline
post #2 of 13 Old 11-04-2012, 10:02 AM
erics diesel's Avatar
Check the fuses under the hood IIRC each circuit has its own fuse
95 f250 eclb 4x4 under construction
96 f250 eclb 4x4 rosewood stage 1 injectors, bully dog 6 position chip, 6637 air filter, idm mod
erics diesel is offline
post #3 of 13 Old 11-04-2012, 10:04 AM Thread Starter
Well, thats issue #1, but issue #2 is adding the 3 remaining missing wires
~Mike Lewis
265,000MI
post #4 of 13 Old 11-04-2012, 10:06 AM
Do you have a brake controller
post #5 of 13 Old 11-04-2012, 10:26 AM Thread Starter
yes
.klsrtjuhg;oertihjnbflkd
~Mike Lewis
265,000MI
post #6 of 13 Old 11-04-2012, 10:47 AM
early99psd's Avatar
Quoted: 12 Post(s)
If its an factory plug then it is plugged into the factory harness. If its not the anything is possible. In a 7 way plug you have running lights, right turn, left turn, back up lights, brakes, hot, and ground.
MB HPOP, PHP Hydra, AFE stage 2, 4" turbo back exhaust, gutted cat, ford reman trans, JW valve body, 6.0 trans cooler, EGT trans temp boost gauges, Hutch and Harpoon mod, riffraf FRx, Pro Comp leveling kit, 1" zone shackels, 08 rear diff cover, 315 Toyo AT2,
early99psd is offline
post #7 of 13 Old 11-04-2012, 10:56 AM
Quoted: 77 Post(s)
Feedback Score: 4 reviews
Lots of info here. Trailer Wiring Diagrams | etrailer.com
Jack
97 F250 Xlt, built E4od, D60 swap, Baby swamps, tunes by Dp
1.0 housing w/ wwII, 203* t-stat, diy 6637, 4" exhaust
Diy intercooled, 6.0 fan, Diy 140v Idm, Isspro Ev gauges
On board air, E-fuel, 6" lift on 35's
322000 miles
1Dieselman is offline
post #8 of 13 Old 11-04-2012, 11:28 AM
Turbostang500's Avatar
I dont think one pin is for reverse lights although it could be used for it. That pin is meant for charging a battery in/on the trailer.
Lee
2000 F250 PSD SCSB 4X4 418k miles straight pipe gauges 2" leveling kit 315/75r16's
6637 with custom intake pipe. TS Performance 6 position chip!
[/URL]
Please don't confuse my attitude with my personality.. my personality is who I am,my attitude depends on who you are...
Turbostang500 is offline
post #9 of 13 Old 11-04-2012, 11:37 AM
early99psd's Avatar
Quoted: 12 Post(s)
The only difference between a 6 and a 7 way plug is the reverse lights. They both have a hot for charging the battery.
Sent from my iPhone using Autoguide.com App
post #10 of 13 Old 11-04-2012, 11:39 AM
Cool, didn't know that!
Thanks
Lee
[/URL]
