removing injector top - Ford Powerstroke Diesel Forum
Old 11-03-2012, 03:16 PM
Send a message via AIM to tristanlee85 Send a message via MSN to tristanlee85 Send a message via Yahoo to tristanlee85
I am in the process of replacing the glow plugs and decided to do new valve cover gaskets as well. While unplugging the injectors, 1 of the plugs had a piece break off up in the connector. So I'm not able to plug in my new harness until I remove the piece still up in there. From this image, it's up in the left corner - very small piece preventing me from plugging in. there are 4 torx screws on top the connector. Can I remove those to remove the connector and clean out the broken plastic or do I have to remove the whole injector?
Old 11-04-2012, 02:31 PM
the baconator
yes you can undo the solenoid, just remember to put it back the way you found it
