trying to figure out what's wrong with my truck - Ford Powerstroke Diesel Forum
post #1 of 11 Old 11-01-2012, 06:36 PM Thread Starter
Starts and runs just fine, has an intermittent miss between 1500 and 2200 rpms. It kinda cuts out then picks up like somehow I instantly added a cylinder or two? It started and died twice trying to leave from work. Ran rough intermittently all the way home. I replaced fuel filter old was wasn't that dirty. Replaced cps. What should I look at next. It's been at a diesel shop for over a week and they keep telling me they are too busy to have a look. Any idea's would be appreciated. I might bring it home if it will make it.
ToddM715 is offline
post #2 of 11 Old 11-01-2012, 10:59 PM
Check the valve cover harnesses above and below the valve cover. They like to burn up. My did the same thing your describing when mine burnt awhile back til finally it stopped running
zombiediesel is offline
post #3 of 11 Old 11-02-2012, 03:21 AM
Turbostang500's Avatar
Agreed. That is the first place I would check. I would also have it scanned for codes.
Lee
2000 F250 PSD SCSB 4X4 418k miles straight pipe gauges 2" leveling kit 315/75r16's
6637 with custom intake pipe. TS Performance 6 position chip!
[/URL]
Please don't confuse my attitude with my personality.. my personality is who I am,my attitude depends on who you are...
Turbostang500 is offline
post #4 of 11 Old 11-02-2012, 07:51 AM
BANNED by Kris
BigFuel's Avatar
Quoted: 57 Post(s)
x3 Agreed. Easy fix.
Matt
-'97 Mini Monster
-Bean's: 160/100 (FF Injectors), 2/ 6-POS chips (TW & Beans tunes), Overboost controller, E-Fuel
-BANKs: downpipe, full exhaust, gauges, intercooler
-Irate: T-4 kit, IC pipes, 3" Irate Plenums, BASB Turbo
-Stage II trans.
-Mag-Hytec trans. and pumpkin covers
-6637, CCV, IDM, 6.0 Fan, 49-Federal PCM swap, MAP line Mod
-370 Amp alt., 40k trans cooler, ADRENALINE PUMP
-twin on-board air w/ 10 gal. tank
-'15 F350 6.7L DRW 4x4
BigFuel is offline
post #5 of 11 Old 11-06-2012, 09:25 AM Thread Starter
The shop tested everything and said they couldn't find anything wrong. They test drove it twice and said it runs great. Then they said my water in fuel light came on and wouldn't go off. They couldn't tell me if the mechanic drained the fuel bowl or not. This was the second shop it was at and neither shop checked for water in the fuel. I drove to my friends house and we drained the fuel bow and found a lot of water and murky looking fuel. What's the easiest way to remove this? Should I pull the tank? it's the front tank. Or will siphoning and new fuel be OK? Thanks everyone.
ToddM715 is offline
post #6 of 11 Old 11-06-2012, 09:36 AM
kblv247's Avatar
drop the tank and clean it out!
kblv247 is offline
post #7 of 11 Old 11-06-2012, 12:45 PM
erics diesel's Avatar
Make sure you clean your fpr screen and I would also recommend running some diesel clean or similar through the system
95 f250 eclb 4x4 under construction
96 f250 eclb 4x4 rosewood stage 1 injectors, bully dog 6 position chip, 6637 air filter, idm mod
erics diesel is offline
post #8 of 11 Old 11-08-2012, 05:47 AM Thread Starter
I cleaned the fpr screen a couple of weeks ago. How often should this be done? I also have been draining the water out every time I drive it. I add diesel clean or some diesel additive to every tank. Is there an additional water seperator/fuel filter I can add inline somewhere to help with catching more water that is easier/cheaper to clean/change? Thanks everyone
ToddM715 is offline
post #9 of 11 Old 11-08-2012, 06:24 AM
Might also want to try filling up at a different station sounds like they might have a water in fuel problem
post #10 of 11 Old 11-08-2012, 07:35 AM
BANNED by Kris
BigFuel's Avatar
Quoted: 57 Post(s)
E-Fuel. The filters and water separators are now on the frame rail and a lot bigger.
Matt
-'97 Mini Monster
-Stage II trans.
BigFuel is offline
