Turbo "Whoosing"
I bought this truck back in August and have had a Whoosing sound coming from the turbo/exhaust. When it's warm out it does it upon start up and then that's it. It sounds like a popoff valve or vacuum leak then you can hear it "seat". Well this morning it was 32 degrees here when I started it and it didn't do it on start up. I let it warm up about 20 min before I left for work. When I would accelerate I could hear the " Whoosing" and then "seating" up til around 1200 rmp and it was very sluggish. When it seated I noticed the power come back. As soon as I would let off and accelerate again, it would do it again. After I drove it about 5 miles it quit doin it all together. Any ideas what it might be?
This is your exhaust back pressure valve closing... the computer is closing it to help warm the engine up faster, altho i dont know how well it works. If it annoys u just disconnect it on your turbo pedistal and make sure the vale is open and wire it open for insurance, or leave it alone and run it as it is
Should it be doin it while I am trying to drive, causing it to run crappy? Would changing it help or is that just normal?
It will do it until the pcm thinks the engine is warm enough. Most of us just disconnect it
So just disconnect and wire it open? It won't throw any codes or make lights come on?
Once you unplug it, it will always be open. And no you wont throw any codes once you unplug it. Had mine unplugged for at least 4 yrs now. No need for it
It will throw a soft code but the light will not cone on but if you hook it up to a scanner it may show the code for it
Alright. Thank you guys for the information. Much appreciated!!
Plus is underneath the turbo, accessible from the drivers side of the vehicle. Should be hard to miss.
You are not letting the truck warm up for 20 minutes are you? A couple of minutes is plenty. Just ease into the throttle until the needle comes up.
