help locating 7.3-e4od spacer - Ford Powerstroke Diesel Forum
Old 10-29-2012, 02:59 AM
ok so i cant find this spacer online. we are about to get hit with this damn hurricane so i will call my tranny guy once it all passes, but if anyone has one lying around please let me know. like i said its for a PSD out of a 94 1/2 and im bolting a 94 e4od tranny to it. and i need that "stress ring" or whatever its called which goes on the bolt side of the flexplate (thin washer stile ring that goes over the flexplate and the bolts go through it. Also i have an IDI motor lying around if anyone needs anything just looking into my previous threads. Thanks in advance guys.
i did find these part numbers but no pictures to verify that its the right spacer that is thick enough to clear the flexplate from the block
F5TZ 6A366-A---------spacer
F4TZ 6A366-A---------stress ring any help is appreciated thanks in advance guys
__________________
Old 10-29-2012, 06:23 AM
Delivers Pizzas For Fun!
I belive i have one..... the spacer that bolts between the trans and the engine? Also has the hole for the starter to bolt to..
Old 10-29-2012, 06:33 AM
as long as the spacer you are talking about is the same for auto vs manual tranny i have that one (i have one for manual) . The spacer im talking about attaches the crankshaft to the flexplate. Its about 4" round but im not sure how thick it is. also looking for a complete in cab wiring harness for a 7.3 PSD auto trans as well
Old 10-29-2012, 06:33 PM
Nope, mine is more of a bellhousing spacer, sorry.
