removing spindle how to - Ford Powerstroke Diesel Forum
Old 10-28-2012, 09:57 AM
im trying to remove my spindle off the knuckle and its giving me hell.
ive heated, beat with no luck.
ive heard there is a slide hammer that can thread onto the spindle so i can pull it off but they dont have them at the parts stores around here.
anyone have any advice?
Old 10-28-2012, 02:41 PM
AutoZone has the tool 4WD Spindle Puller | AutoZone.com
Old 10-28-2012, 03:53 PM
ok i guess they dont know they have it...i called and asked...ill just have to stop by myself
Old 10-28-2012, 04:04 PM
the baconator
i've heard of the slide handle spindle puller but never used one. i always wrap two thick magazines around the spindle and then a layer of cardboard and then hit it with a big hammer couple of hits and it loosens and the put a pry bar behind the spindle and tap and pry. done many that way. you just need to be careful not to damage the threads. you could use a piece of bronze too so you don't damage the threads
Old 10-28-2012, 05:53 PM
ive beat it all day with no luck, ive searched all over the internet for the little tips and tried them all except the slide hammer. hopefully i can get one tomorrow and it will be the trick
Old 10-28-2012, 11:01 PM
When I was figiting a stuck spindle, I cut the upper ball joint and pressed the spindle out of the knuckle with a 20 ton press. I recommend using lots of antisieze during reinstallation.
Old 10-29-2012, 02:47 AM
Yeah I just used a heavy dead blow plastic hammer and beat the hell out of it.
I painted it with so much anti seize when I put it back together it was basically dripping off. Won't have that problem again hopefully.
Old 10-29-2012, 02:41 PM
well i finally got it off. if you havent tried the puller tool then next time its a must! Its free to rent so why not!?
It still took about a good 100 blows but it finally came off. way quicker than the 5 hours i spent yesterday monkeying around with heat and chisels.
