Standard Tranny Fluid - Ford Powerstroke Diesel Forum
post #1 of 20 Old 10-28-2012, 09:39 AM Thread Starter
95Strokeee's Avatar
Hey everyone, I am looking to possibly change the transmission fluid. I have the ZF5. Can i use synthetic? What fluid does everyone use? Thank you!
95Strokeee is offline
post #2 of 20 Old 10-28-2012, 09:43 AM
erics diesel's Avatar
I use synthetic atf in mine
95 f250 eclb 4x4 under construction
96 f250 eclb 4x4 rosewood stage 1 injectors, bully dog 6 position chip, 6637 air filter, idm mod
erics diesel is offline
post #3 of 20 Old 10-28-2012, 02:39 PM Thread Starter
95Strokeee's Avatar
Right on. Can you put that in a manual transmission?
post #4 of 20 Old 10-28-2012, 02:54 PM
Yes atf is what the manual trans takes
post #5 of 20 Old 10-28-2012, 03:15 PM
backwoodsboy's Avatar
Ford filled the ZF-5 with ATF from the factory. However it was designed (as with all MT & MTX's) to be filled with manual transmission fluid. ATF will do the job, but typically shortens the duty cycle of the unit by ~20%.
It all comes down to cost benefit analysis. If 90% of vehicles use an auto and 10% use manuals, Ford saves money by filling their MT's with ATF as long as the duty cycle still exceeds a typical 100,000 mile warranty period.
Chrome don't get ya home
backwoodsboy is offline
post #6 of 20 Old 10-28-2012, 03:49 PM
Diesel_brad's Avatar
Quoted: 4 Post(s)
Ford and ZF calls for SYNTHETIC ATF. Ford used Castrol Synthetic ATF form the factory, it was actually green
Looking for Blue 40-20-40 seats. PM me !!!!!!!
Diesel_brad is offline
post #7 of 20 Old 10-28-2012, 04:04 PM
As a cost saving measure for the end manufacturer (FoMoCo). Simple as that. Chrysler and GM did the same with NPG/NVG products. There is no reason to put ATF in a manual transmission other than cost savings.
post #8 of 20 Old 10-28-2012, 04:08 PM
Quoted: 4 Post(s)
I have seen MULTIPLE Abused trucks make it well over 200k with the Original fluid still in it. It must work just fine.
God knows the Castrol Synthetic ATF is NOT cheap
post #9 of 20 Old 10-28-2012, 04:25 PM
Cost saving isn't due to the product used as much (although buying in bulk would save a few $), as from minimizing variance between different units. If you're filling two million units a year, minimizing the number of assembly lines needed to do so will be cost effective.
The ZF is a stout unit, no doubt. I'm in no way saying that ATF is the cause of premature failures. The fact that MTF will protect better against synchronizer wear isn't debatable though.
post #10 of 20 Old 10-28-2012, 04:49 PM
Quoted: 4 Post(s)
You are missing the point. the autos got REGULAR ATF. The GASSER ZF and Mazda manuals got REGULAR ATF. But the diesel ZF got SYNTHETIC Castrol ATF.
