HPOP anti drain valve? - Ford Powerstroke Diesel Forum
post #1 of 3 Old 10-27-2012, 05:06 PM Thread Starter
Quoted: 8 Post(s)
My dad has a 1995 7.3 and the HPOP reservoir leaks down after a day or two. I've found that the early '94-'95 HPOP had an anti drain valve and the only picture I've found of this shows it in passage coming from the IPR valve. Is this correct?
2016 F250 Platinum 6.7 Powerstroke
BlkSC is offline
post #2 of 3 Old 10-29-2012, 09:31 AM
BANNED by Kris
BigFuel's Avatar
Quoted: 40 Post(s)
No the picture is misleading. I believe this is what you are looking for. It is in the valley under the valley cover. Upper left of the picture.
Matt
'97
-Bean's: 160/100 (FF Injectors), 2/ 6-POS chips (TW & Beans tunes), Overboost controller, E-Fuel
-BANKs: downpipe, full exhaust, gauges, intercooler
-Irate: T-4 kit, IC pipes, 3" Irate Plenums, BASB Turbo
-Stage II trans.
-Mag-Hytec trans. and pumpkin covers
-6637, CCV, IDM, 6.0 Fan, 49-Federal PCM swap, MAP line Mod
-370 Amp alt., 40k trans cooler, ADRENALINE PUMP
-twin on-board air w/ 10 gal. tank
-Oh, and a 2015 F350 6.7L DRW 4x4
BigFuel is offline
post #3 of 3 Old 11-01-2012, 06:46 PM Thread Starter
Quoted: 8 Post(s)
I believe that's the quick fill check valve for when the engine first starts up. The one I'm talking about is only on the '94 and '95 engines. I found a picture of it circled on the HPOP and looking at the face where it mounts, it's on the upper drivers side which is the oil return after the IPR valve. If that's where it's supposed to be then my dads is missing but I'm really not sure where it could have gone. If someone could verify that's where it is, I'd appreciate it.
BlkSC is offline
