Need early 99 intake spider/Y
Does anyone have a early 99 intake spider/y sitting around they want to get rid of? I am putting a 7.3 intercooler on a 1995 7.3. I have the intercooler, pipes and boots, just need the spider. Any suggestions in getting around this with a 99.5 or newer spider/Y? Thanks.
Good luck. Keep your eyes open on ebay and the forum classifieds
Might also use searchtempest.com
How hard is it to use a late 99 and later Y? I will ahve to replace the plenums to 3", is that it?
I don't think the 3 inch plenums will work with the factory fuel bowl there
I believe e-fuel is required.
E-fuel and 3" plenums will let you run a 99.5+ intake spider.
I believe the turbo would need changed also because the turbo compressor outlet is a different size.
I am in the process of an E-fuel conversion and EBPV delete because it is leaking oil. I could upgrade the plenums now if needed, but if the turbo won't fit, i don't plan on replacing that as it seems to be in good condition.
big97fordpowerstroke- is your extra spyder at e99? if so I am interested. |
