97 psd that wont shift from 2-3. help - Ford Powerstroke Diesel Forum
post #1 of 4 Old 10-26-2012, 12:28 PM Thread Starter
I have a 97 psd that will only shift into third if you rev the engine high then let off the accelerator. After that shift, the other shifts are fine. I have replaced trans fluid and filter. Old fluid did not smell burnt. I cleaned the vss and unplugged all electrical connections to trans and added die electric grease and replugged. Nothing has helped. Could this be a solenoid pack problem. The truck has 189k. I dont want to take it to a tranny shop. any help will be greatly appreciated. thanks
1997 f250hd xtra cab 4wd lb. Psd. Ccv mod, superchip.
atstew42 is offline
post #2 of 4 Old 10-26-2012, 01:33 PM
Quoted: 83 Post(s)
Feedback Score: 4 reviews
Will it manually shift through the gears? It is possible that you have a intermediate seal on it's way out
Jack
97 F250 Xlt, built E4od, D60 swap, Baby swamps, tunes by Dp
1.0 housing w/ wwII, 203* t-stat, diy 6637, 4" exhaust
Diy intercooled, 6.0 fan, Diy 140v Idm, Isspro Ev gauges
On board air, 38 Gal rear tank, E-fuel, 6" lift on 35's
322000 miles
1Dieselman is offline
post #3 of 4 Old 10-26-2012, 01:48 PM Thread Starter
1Dieselman
It does manually shift. Is that a good sign??
atstew42 is offline
post #4 of 4 Old 10-26-2012, 05:14 PM
Quoted: 83 Post(s)
Yep that's a good sign. Sounds like maybe the 2-3 shift spool in the valve body is sticking
Jack
322000 miles
