bearing locknut how to remove
im removing my right front knuckle and im down to the bearing locknut which needs that special 4 prong socket.
i have bought the recessed prong one like this one ToolKing.com: OTC 7158 Ford F-Series FW Bearing Locknut Socket and the one with the prongs sticking strait out but both are too small in diameter. the locknut is bigger. who knows which tool is for this axel? i believe i have a 1992-1994 dana 60 because it has the slide calipers on the kncukle. i have checked autozone and advanced auto |
![]() Or use a brass punch and hammer to remove the nut and take it to the tool store to find the right one. They are not on tight. Generally no more than a half turn past touching. |
i can give it a shot, just recessed enough to make it hard though.
As long as the keeper is out/bent back (don't remember which one you have) all the hub nuts are just past hand tight.
Sent from my Galaxy S2 while my wife is yelling at me for being on my phone... |
FoMoCo Part #: D85T-1197-A
Any parts store should be able to find you a compatible tool if you take them that part number. |
ok ill check again tomorrow when i return these
