new to the 7.3 - Ford Powerstroke Diesel Forum
post #1 of 9 Old 10-22-2012, 02:27 PM Thread Starter
new to the 7.3
im new to diesel and been asking friends about the 7.3 and getting different things. but i rather hear it from you guys what do you think of this truck im looking at lifted 1997 powerstroke
i know to do the oil pan engine needs to come out but its not leaking that that bad. and door handles 4x4 link i can do. but what do yall overall think? thanks chris
speedman8903 is offline
post #2 of 9 Old 10-22-2012, 04:29 PM
Quoted: 77 Post(s)
Feedback Score: 4 reviews
Doesn't look like to bad of a deal. A couple of things, these engines use a sealant for the oil pan gasket and they seldom leak from there, the leak usually comes from the rear main seal, rusted out pan, oil cooler o-rings, turbo pedestal o-rings and runs down the back of the block, or the dipstick tube where it enters the pan. If it is the oil pan sealant/gasket the engine needs to come out of the truck to fix. The intercooler, D66, trans, etc where all expensive upgrade's so that is good. I would inspect the impeller on the air inlet side of the turbo because of that really crappy K&N air filter that is on there.
Jack
97 F250 Xlt, built E4od, D60 swap, Baby swamps, tunes by Dp
1.0 housing w/ wwII, 203* t-stat, diy 6637, 4" exhaust
Diy intercooled, 6.0 fan, Diy 140v Idm, Isspro Ev gauges
On board air, E-fuel, 6" lift on 35's
322000 miles
1Dieselman is offline
post #3 of 9 Old 10-22-2012, 04:57 PM
the baconator
terryknight's Avatar
Quoted: 141 Post(s)
i agree with jack not a bad deal though i wouldn't call a lift good (personal opinion) it adds unneeded stress. also the upgrades need to be done well without shortcuts or they can be headaches. but the motors are dependable, and easy to work on and this is a great site with lots of knowledge. take it for a ride and report back. make sure you get to start it cold.
94.5 F250 Reg Cab 4x4 5 speed 4.10 276000 plus miles
97 F350 Crew Cab LB 4x4 5 speed 3.55 320000 plus miles (parts truck)
Originally Posted by alberta 7.3 View Post
YouTube: Providing idiots everywhere a podium to share their stupidity
terryknight is offline
post #4 of 9 Old 10-22-2012, 05:56 PM
backwoodsboy's Avatar
Looks like a pretty respectable deal. Make sure to see receipts on any work/upgrades.
Not sure that is a K&N filter. Looks more like an AFE filter that someone tried cramming in behind the battery box, instead of buying the intake kit. Either way, in the crumpled condition it's in I would agree turbo dusting is a possibility.
Cold start is crucial. Before you start the truck up put your hand on either the exhaust side of the turbo housing, collector, or up-pipe. If it is warm, then the guy had the truck running before you showed up and is trying to pull a quick one. The components will heat up much quicker than the engine itself.
Chrome don't get ya home
backwoodsboy is offline
post #5 of 9 Old 10-22-2012, 06:18 PM Thread Starter
I'm going to check all those places before doing the oil pan. Might be something else leaking and he thinks its oil pan. How do I check the turbo? Yeah I like the lift but I really like the truck cause its the cleanest one I've found. And for sure want to start it cold and keep her idling to make sure nothing else is wrong with it. No air leaks anything like that. Anything else you guys think I should check other than stated and the obvious? Thanks for the help and replies guys!
post #6 of 9 Old 10-22-2012, 06:25 PM
Quoted: 77 Post(s)
Read this, http://www.powerstroke.org/forum/7-3...94-98-psd.html
Jack
322000 miles
post #7 of 9 Old 10-23-2012, 08:26 AM Thread Starter
thanks jack i read it last night going to check everything on wednesday when i go look at it. those 4:11 gears should be good for towing then correct?
post #8 of 9 Old 10-23-2012, 08:36 AM
Quoted: 77 Post(s)
The 4.10 gears will help but won't be the greatest if it has larger than 315/35" diameter tire's
Jack
322000 miles
post #9 of 9 Old 10-23-2012, 12:47 PM Thread Starter
i was thinking of putting 22x14 fuel hostage rims and some nice off road tires
