HPOP reservoir leaks down? - Ford Powerstroke Diesel Forum
post #1 of 3 Old 10-21-2012, 06:30 PM Thread Starter
Quoted: 8 Post(s)
I've been working on my dad's '95 7.3 because the HPOP reservoir leaks down after a couple days of sitting. So I replaced the o-rings in the HPOP and replaced the gasket between the HPOP and timing cover. And it still leaks down 6 or so inches.
I finally hooked up an oil pressure gauge in the port by the oil filter and tried to start the truck with the reservoir basically empty. Cranked it over for 20 seconds or so with no oil pressure registering on the gauge. Cranked it over again for 15 seconds or so and it fired up. Right before it started the oil pressure on the gauge started going up and once it was running it had about 50 psi of pressure.
But something I just realized today is that I'm pretty sure the HPOP didn't have a check valve in it even though the gasket that came off was the correct one for the HPOP with check valve.
So...can that check valve some how come out and disappear into the engine without it damaging anything? Or does it sound like the oil pump might be bad and allowing the oil to drain back?
2016 F250 Platinum 6.7 Powerstroke
BlkSC is offline
post #2 of 3 Old 10-22-2012, 04:44 PM Thread Starter
Quoted: 8 Post(s)
Or how could I check for sure to see if maybe the IPR valve is sticking open?
BlkSC is offline
post #3 of 3 Old 10-23-2012, 08:09 AM
BANNED by Kris
BigFuel's Avatar
Quoted: 50 Post(s)
To test the ICP with a DVOM:
To test the IPR with a DVOM:
Matt
-'97 Mini Monster
-Bean's: 160/100 (FF Injectors), 2/ 6-POS chips (TW & Beans tunes), Overboost controller, E-Fuel
-BANKs: downpipe, full exhaust, gauges, intercooler
-Irate: T-4 kit, IC pipes, 3" Irate Plenums, BASB Turbo
-Stage II trans.
-Mag-Hytec trans. and pumpkin covers
-6637, CCV, IDM, 6.0 Fan, 49-Federal PCM swap, MAP line Mod
-370 Amp alt., 40k trans cooler, ADRENALINE PUMP
-twin on-board air w/ 10 gal. tank
-'15 F350 6.7L DRW 4x4
BigFuel is offline
