auto to 5 speed swap? want your opinion
I've got a 97 ECLB with the E40D. The truck currently has ~210,000 miles on it with the factory tranny. I haven't had any problems with the transmission even with loads up to 16,000 lbs in tow. I went to a junk yard today to pull a couple interior parts to my truck and found a '96 CCLB dually with all the parts I would need to do a 5 speed swap. I understand that i would either have to find a driveshaft or have one made and also get a new clutch but besides that everything is there. The guy said he would sell me everything for about $550. My thought is to just buy everything and put it in my shop until my tranny blows and then do the swap. I'd like any and all input that yall have and especially from yall that have done it.
Thanks for reading. |
Is the donor truck a 7.3?
Yes it is. The only difference is that the manufacture date is 04/96 vs mine which is an 03/97. And its a CCLB dually vs mine, a ECLB SRW.
is your truck two or four wheel drive?
Both are two wheel
Make sure you grab the PCM. This will save you having to reflash yours. An auto PCM will run a manual, but there are issues with rough idle and throttle response.
Other than that it should be fairly straight forward. |
Ok thanks for the info. I had no idea about that. Are there any other electronic things that will need to be changed out. Also if I change out the gauge clusters will the mileage read what is on my truck or will it be what was on the other?
Yes. Mileage is stored electronically in the gauge cluster. Ford did not start storing mileage in the PCM until 2003 I believe.
There are a few minor electronic things that need to be swapped out. No harnesses or anything major. I believe there are 4 wires that need to be re-arranged on the gear selection plug in order for the truck to start. Can't remember exactly right now. Last edited by backwoodsboy; 10-09-2012 at 07:47 PM. |
Ok thanks. Ill try to keep reading up on the threads that people have done about the swap
