My pickup wont run in the winter? - Ford Powerstroke Diesel Forum
post #1 of 31 Old 10-08-2012, 03:29 PM Thread Starter
So my pickup wont run when its cold. I talked to the previous owner and he said it didnt run for him in the winter either.
What could be wrong?
Rocking Ford is offline
post #2 of 31 Old 10-08-2012, 03:36 PM
erics diesel's Avatar
does it just crank and no fire?
95 f250 eclb 4x4 under construction
96 f250 eclb 4x4 rosewood stage 1 injectors, bully dog 6 position chip, 6637 air filter, idm mod
erics diesel is offline
post #3 of 31 Old 10-08-2012, 09:15 PM Thread Starter
yeah. it will kinda fire but then die...
post #4 of 31 Old 10-08-2012, 09:21 PM
Quoted: 5 Post(s)
Does it crank and run when it's been plugged in?
ianstew is offline
post #5 of 31 Old 10-08-2012, 09:29 PM
atvrider93's Avatar
Quoted: 8 Post(s)
Check the GPR. If that's good check the resistance on the GPs
1996 F350 4x4 CCLB-- I'll miss her
1996 F350 4X4 RCLB zf5 213K
6637
OBA w/horn
DE 5"
PHP tunes
Mud Country 315/75/16
2008 Wr250X
Originally Posted by belz View Post
There u go Tom. John may not be sexy, but he can tutor you, lol.
atvrider93 is offline
post #6 of 31 Old 10-08-2012, 10:17 PM
strokin95style's Avatar
like mentioned above, more than likely glowplugs or relay. check the relay first. I ditched the oem relay and went with a Stancor 586-902 like everyone talks about, had it for a year and a half and no problems so far. I was replacing oem relays about twice a year.
Nater
1995 f-250 rclb
7.3~317k miles & countin
3" Downpipe
Superduty 10.5" 3 pinion Trac-Lok rear
Dana 60 s.a.s
1997 ccsb , 353,500 miles
5" lift on 315x75x16 cooper at3's.
Clear headlights, tinted tails, rear buckets,
Dana 60 swap, zf5 swap.
rosewood 180/100's, t500 hpop, php hydra, e fuel.
strokin95style is offline
post #7 of 31 Old 10-09-2012, 05:24 AM Thread Starter
I havent tried with it plugged in yet, but I plugged it in last night so ill know in a little bit. And I will check the gpr and gp's.
post #8 of 31 Old 10-09-2012, 07:49 AM
Could be gp, grp, bad filter, bad fpr screen. Check them all.
85_305 is offline
post #9 of 31 Old 10-09-2012, 11:38 AM Thread Starter
so I plugged it in last night, and this morning when I tried to start it it turned over for a little bit then fired up. And it kept running so I drove it to school today. It hasnt been plugged in sense 7:30 this morning so I hope it starts after school...
post #10 of 31 Old 10-09-2012, 11:38 AM Thread Starter
could It just be that cold blooded that it has to be plugged in if its 20 Degrees or below?
