Egt's, boost, fuel pressure
Hey im gonna get these guages here soon and would like to know what boost a stock 7.3 runs and what one with a normal (if there is a normal) avg ts 6 position chip has on the diff tunes. Also what is a normal egt and what egt do you not what to get up to. (whats the green yellow and red #s) and lastly what is the fuel pressure of a 7.3 I have the 1995 Powerstroke. Thanks guys!
Sent from my PG86100 using AutoGuide.Com Free App |
Stock boost about 15-18 psi with a chip 22-25 psi. Egt's 1200-1250* is normal but cooler is better, can get up to 1400* for a short time anything over 1400* is time to be concerned and back out of the throttle unless you are racing or sled pulling but that is a whole new ball game. Fuel pressure should be approximately 65 psi at all times. If the fuel pressure drops below 50 psi while hard on the throttle for a extended period of time it's time to find out why.
auto or manual if auto I advise trans temp gauge
also for gauges i recomend isspro ev2's
Thanks man, much appricated! And I have a 5 speed, and thanks as well, you all on this fourm have helped alot and saved me some $$$$$
http://item.mobileweb.ebay.com/viewi...id=75145720468 I was looking at these, just because of my small budget, but are these to cheepy? I was gonna get the mentioned guages tho
I've never used the glow shift gauges but I have heard a lot of people are happy with them but just as many say don't waste your money on them. I got my Isspro EV's from here Isspro and Autometer Gauges He has really good prices on gauges and excellent customer service.
I had to make another reply to this with the ratio showing up how meny views and replys wasent a good #
And thanks ittl be a month or so before I can afford n e thing so ill shop around Sent from my junk EVO 3D using AutoGuide.Com Free App |
I was getting 15 psi stock and could hit 1100 degrees. With intake, exhaust, and Wildman chip I hit 18 psi and just over 1200 degrees towing up hard hills.
Thanks, the only thing I have is a S&b intake, a 3in downpipe to a 5in stright, and a ts 6 position switch and idk what Tunes are on it, I dont have the knob, it was broke when I got the truck so I spliced the wires and use it that way.. haha
