Resealing timing cover? - Ford Powerstroke Diesel Forum
Old 09-25-2012, 10:43 PM
Anyone resealed the toming cover on a obs? I think mines leaking and want to know how bad a job it is and whats required?
Old 09-26-2012, 11:57 AM
Aside from removing the engine, the rest should be cake! As far as sealants go, you can't beat these:
Sealant (Wacker)
Intake Plenums: Motorcraft TA-30 (used to be Ford part F7AZ-19554-EA)
Everything else (oil pan, etc): Motorcraft TA-31 (used to be Ford part F5TZ-19G204-AB)
Cheers!
Old 09-26-2012, 12:00 PM
Cant i just pull core support then do it intact?
Old 09-26-2012, 01:25 PM
I used Permatex's The right stuff in the caulk gun, works great.
Old 09-26-2012, 03:06 PM
For the timing cover?
Old 09-26-2012, 04:41 PM
Thumbs down
Nope. You have to remove the engine as Patrick mentioned
