Warm up/glow plug questions.
I have a 97 F250 with 275k miles. Truck seems to be in pretty nice shape. I am new to diesel vehicles. I know how diesels work but not all the tricks.
When I turn the key on I let the glow plugs warm for about 30 seconds. About 60-70 outside temp. If I start it sooner, I get a lug... lug... lug... several times. Guessing it is a cold engine. If I drive about 10-15 minutes say to the store, run in and out quick, crank the engine I still get a Lug... lug... a couple times. Do you need to cycle the glow plugs every time??? My buddy has a couple 7.3s at work and sounds like they just hit the key and go. When the weather gets cold (winter coming up) how long to you let the glow plugs warm up? Any tips???? BTW I heard you can check the glow plugs by using a ammeter. Any one have a wiring diagram so I can check the wires out side the valve cover without taking the cover off??? Guessing individual wires going to each glow plug??? Thanks |
In the mornings (about 60-70 degrees) mine just comes right to life with out any heat, I don't do it often, but it does.
I know that isn't an answer, but it is something to compare notes to. |
Mine too sometimes I just crank her no glow plugs. Even at 50 degrees she fires
Sent from a Apple |
I have done a few minor repairs. Just trying to get any quirks worked out. |
Is it turning over slow? Or just turn over a few times before it starts?
^ Good question. 2 totally different things. diesels like huge batteries with lots of cca's that are in great condition.
Might be bad gpr, might be bad gp's (not as likely), might be a gunked up FPR screen, or might be bad batteries. |
Also when it did start there was a fair amount of smoke. When the gps are on or a while I get no smoke. What is a FPR screen??? |
Got it... Quick search... FPR screen... Will have to check it out.
Ya def check it out! That little thing caused me a LOT of starting problems, just like you.
Like romp start? Sounds like a big cammed racecar romp,romp,romp?
