alternator bouncing back & forth makes lights flicker ? - Ford Powerstroke Diesel Forum
Old 09-23-2012, 12:16 PM
My gage is going up & down with the motor makes lights go dim & bright right along with it , would that be voltage regulator taking a crap ?
Old 09-23-2012, 12:25 PM
sounds like it could be but also check the big wire on the back of the alternator for corrosion
Old 09-24-2012, 05:02 AM
Does it do it on startup? Sounds like the initial GP draw on startup.
Old 09-24-2012, 01:13 PM
No it does it driving at full speed....
Old 09-25-2012, 02:59 AM
Right... after a cold-start? Will still flicker while driving if the GPR is on.
Old 09-25-2012, 01:40 PM
it dont flicker it goes in & out all day & all night long my lights go bright then dim all night not right after start , my budy says my alternator is going out..
Old 09-25-2012, 02:14 PM
my dads truck did the same thing when the alternator went out
Old 09-26-2012, 03:03 AM
In that case yes it sounds like alternator. Stick a multi meter up to the output on the alternator and see what it reads when all of this happens.
