turbo - Ford Powerstroke Diesel Forum
Old 10-15-2007, 09:20 PM
turbo
I was woundering how much of a boost difference there is between a 2002 7.3 turbo and a 1996. I got the 02 and want to put it in my 96 7.3
Old 10-16-2007, 06:24 AM
It wont fit on there, there are multiple things different on your truck compaired to an 02. The turbo pedistal and exhaust up-pipes, and some othere stuff all need to be changed, Its quite involved to change an old body style truck like yours to a new style turbo. Your best bet for a turbo upgrade is a D66 turbo from Beansdieselperformance.com, its a direct bolt on and flows some good air, much more than a stock 02 turbo could ever dream about.
Old 10-16-2007, 08:28 AM
the pedastal I have from the 02 is the exact same as the 96. And to change out the up pipes is a mader of four bolts every thing seems to mach up. Only thing i have to figer out if i want to run an innercooler or make a costom inlet of my turbo.
Old 10-16-2007, 09:08 AM
I wish you luck.
Old 10-16-2007, 11:19 AM
lukecline
Guest
Posts: n/a
pedistals are not the same. the earlier turbos are better imo, you dont have to worry about surge with them. Also 1 exhaust manifold is different, i think its the driver side.
