Cheap E-Fuel Conversion! For $200 or less!! Write Up - Page 2 - Ford Powerstroke Diesel Forum
 1Likes
post #11 of 98 Old 04-27-2012, 10:45 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
all i can say is the man is thrifty as all hell lol, btw gabe your link dont take you to the sellers store where you got the fpr, just to the ebay home page, i would be interested to read more on that particular seller, and their product, but i guess in a couple months if yours still works fine means they have a pretty good product
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #12 of 98 Old 04-27-2012, 10:49 AM
baderic03's Avatar
Send a message via AIM to baderic03
yes we will. also alot of factors like what he is running for psi and pump gph will all effect the durability of the regulator all the power to him if it works and has no problems
97 f350single cab auto
4:10 axles spooled front axle
3in down pipe to stack
Intake 6637
140v idm mod
Efuel all built In house
II s475 .90 turbine spool....
Irate T4 304ss up pipes
T500 with gen3 pump
450/400s hush power
Comp built Trans 2100 stall converter
Gearhead tunes
531/1080 on 250/200s
baderic03 is offline
post #13 of 98 Old 04-27-2012, 10:52 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
i think he said in another thread he was running 70 psi, and its a mercedes benz diesel fuel pump as well,
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #14 of 98 Old 04-27-2012, 10:55 AM
baderic03's Avatar
idk what it flows for gph and 70psi is stought i run 72psi in my setup
Intake 6637
140v idm mod
T500 with gen3 pump
450/400s hush power
Gearhead tunes
post #15 of 98 Old 04-27-2012, 10:59 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
isn't everyone saying that 65 is optimal? i know you have a lot of go fast goodies, and your set up may require it
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #16 of 98 Old 04-27-2012, 11:00 AM
Gertrude's Avatar
Send a message via Skype™ to Gertrude
gabe can u grab more pics and describe what you did with the fuel lines in the valley? what do u mean you cut the circle out of the banjo? are u still using ur banjo?
and eric are you still doing 140v idms?
Andy=23
Future Mods: Project Revive/Rebuild/Restore
Too many cars, not enough money.
Gertrude is offline
post #17 of 98 Old 04-27-2012, 11:03 AM
baderic03's Avatar
i dont know kris all the efuel systems i build for obs and sd i run at 70-72psi because they hammer on there trucks and have big tunes in them i rather have them run out of oil then fuel neither one are good but
Intake 6637
140v idm mod
T500 with gen3 pump
450/400s hush power
Gearhead tunes
post #18 of 98 Old 04-27-2012, 11:07 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
i'd rather run out of fuel lol, oil is the life line of the heui injection lol, and the whole system, fuel can run out and be fine lol
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #19 of 98 Old 04-27-2012, 11:07 AM
Gertrude's Avatar
basically i need i more in-depth explanation of this
I cut the banjo circle out of the lines and used 2 4" 3/8 hose peices with hose clamps. I had to bend the lines by hand what lines? just a bit to make it perfect but was super easy.
I then connected those lines into a T reducer can u get a pic? that goes from 1/4-3/8 you just cut which part you want. after the T i connected the lines to the Return going to the Tank. what return lines going to the tank?
Andy=23
Gertrude is offline
post #20 of 98 Old 04-27-2012, 11:09 AM
baderic03's Avatar
yes im still doing them and shipping them all over
Intake 6637
140v idm mod
T500 with gen3 pump
450/400s hush power
Gearhead tunes
