Cheap E-Fuel Conversion! For $200 or less!! Write Up - Page 10 - Ford Powerstroke Diesel Forum
 1Likes
post #91 of 98 Old 06-14-2016, 02:17 AM
sbluke55's Avatar
Quoted: 570 Post(s)
Garage
https://www.amazon.com/Bosch-69136-O.../dp/B000BZGGX4
Use this one.
01 f-250, Standard
Rev tech 4" lift,37" military wrangler Mt tires
KC diy 66, Full force 160/100 and custom tunes from PHP
Banks inner cooler and full 4" exhaust, Diy S&B intake
Diy quad feed, Hydra, Isspro boost, pyro, and fuel pressure
3/0 battery cables with military style terminals
sbluke55 is online now
post #92 of 98 Old 06-14-2016, 05:15 AM
judgesblind's Avatar
Quoted: 11 Post(s)
Great thanks! What is the difference in the two pumps?.... er why are you suggesting one over the other?
And x5 on the pics! They would be really handy to have
Clint
96 F-250 4x4 ECLB
Current mods: DIY 6637, CCV mod, gauges, 3" DP to 4" exhaust, 6 pos chip, E-fuel, D60 swap with PMF 2.25" RSK
judgesblind is offline
post #93 of 98 Old 06-14-2016, 07:12 AM
sbluke55's Avatar
Quoted: 570 Post(s)
Garage
The one I posted is a Bosch. Bosch is the oem superduty pump. The one you post is an unknown aftermarket unit.
01 f-250, Standard
post #94 of 98 Old 06-14-2016, 07:32 AM
Quoted: 11 Post(s)
Ahh makes sense. And any recommendations for a mounting bracket for that pump?
And what about using a FPR like this?
Universal Adjustable Fuel Pressure Regulator Oil 100PSI Gauge An 6 Fitting End | eBay
And where can I find fuel filter bases? Im looking at the WIX 24066 for the 30 micron pre pump filter and the WIX 33528 for the 2 micron post pump filter. Obviously the filters are easy to be had but I'm not sure where to find the bases.
I think other than that I've got a good grasp on it. I know Gabe's link for the FPR he used doesn't direct you to it so I'm trying to get these couple parts figured out.
Clint
96 F-250 4x4 ECLB
post #95 of 98 Old 07-22-2016, 09:57 AM
Quoted: 11 Post(s)
So I got my efuel in and have about 1000 miles on it and it appears that it has significantly reduced my fuel mileage. I'm averaging about 10 mpg now with no changes in driving habits. There's no leaks in the system anywhere so I am really at a loss for what could be causing this. I was getting about 16mpg with the stock setup before. I'm also not really noticing the change in throttle response that most people seem to get. I'm running a Bosch fuel pump with a no name fpr off of eBay. Thanks.
Edit: apparently the no name fpr decides what fuel pressure it wants to be at regardless of how I set it. I'm going to return it and I've already got a Fuelab on order. But would an extreme excess in psi cause the mileage drop? I couldn't get the pressure to drop below 85 psi.
post #96 of 98 Old 08-20-2016, 07:21 PM
That Other Guy's Avatar
Quoted: 4 Post(s)
You get it figured out bub?
This may be a thing i tackle in the next couple months cause truck is gonna go in the garage for some much needed maintenance and updates ive been stockpiling and procrastinating on doing.
I thought i had read in the past our trucks will get less than desirable mileage with excessive fuel pressure but dont quote me cause i cant remember where i read it haha.
Anyway post back if youve got it figured.
97 toredor red metallic f350 XLT CCLB ZF5 7.3 4wd
HPO X-over, riff raff up pipes, 1.00 housing, WWII, 3" dp, 4" exhaust, Tymar intake, riff raff boots, 6.0 fan, tow pig in progress
15 white wrangler jku auto 4" MOPAR lift, fox remote res shocks, fox dampner, black rufino nitros, sun shades, hand grips, floor mats, blah ,blah.
00 Dutchman classic 30' 5er
GN attachment in pin box, new roof compliments of wood rot due to leaks, updating interior currently a work in progress.
That Other Guy is offline
post #97 of 98 Old 01-18-2017, 06:53 PM
Quoted: 2 Post(s)
Garage
i wish the photos would let me view them smh
J77F is offline
post #98 of 98 Old 02-17-2017, 06:00 AM
Slimline's Avatar
Word of warning to anyone doing a efuel conversion, I tried using a knock off fuel pump from rockauto and it died with less than 2k kilometers on it. Replaced it with a bosch off Amazon for 125 bucks Canadian (cheap one was about 55) and no issues so far. Dont skimp on the pump or regulator. I used an aeromotive fuel regulator and it has been problem free.
1997 f250 extended can SRW 4x4 7.3 turbo, e4od (mildly built up)
DP Tuner F6 tuned by Jody
Rosewood stage 2 180/80 injectors
Diy intercooled
efuel conversion
t500 hpop ordered, waiting on delivery!
BHAF
4" straight pipe
Swamps IDM
Glowshift pyro, boost, tranny temp and fuel pressure gauges
AIC mod
Diesel site coolant filter
2" body lift and 35" Wrangler Dura Trac's
For Sale: E4od "Punisher" valvebody $150 obo
Slimline is offline
